Starter trigger wire
I have an 88 4runner, factory auto 22RE. All of the EFI/ECM/trans control is gone along with the harness.
It is now a Mercedes OM617/R150 5 speed.
I'm trying to locate a starter trigger wire, there is no fender relay on auto's. Not sure what may have been missed with the neutral safety switch or TCM, I feel like the easiest way to do this is just pick up whatever the starter trigger wire is out of the column.
Does anyone have a pinout or diagram of the column?
From: exo-reality -wave if you see me; Front Range, CO
I don't have those, sorry.
RAD4Runner has some extensive info in his threads about the goofy start circuit that sends starter solenoid current thru the key jobby.
Not 100% certain if it applies to 88's, but its a pretty good edumacation.
Did you make a build thread?
