Starter Rebuild
Old Jan 29, 2013 | 04:04 PM
PM88's Avatar
Starter Rebuild
I'm looking to rebuild the starter on my 1994 Toyota pickup. I assume it's the original starter, because ever since I've had it, it has never been replaced. I've been looking on ebay for rebuild kits and have found a couple, but am not sure if they will work or not. Would anyone be able to tell me if this kit will work for mine or not: http://www.ebay.com/itm/starter-repa...81b01b&vxp=mtr If not, could you please point me to a kit that WILL work for my starter, preferably on ebay. Thank you very much! P.S. I haven't been able to retrieve the part number on my starter.
Old Jan 29, 2013 | 04:10 PM
snobdds's Avatar
The beauty about toyota starters is, they run forever. Usually all they need are new starter contacts and a new plunger, which can be had for less than $20.00...and that is dealer costs. Read this...
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
This is where you can order the contacts from.
Then you might as well get a new plunger while your in there. Go to the following site, enter your vin, and go to the starter section you will see the plunger.
www.toyotapartseast.com
Then your good for another 200,000 miles.
Old Jan 29, 2013 | 04:17 PM
PM88's Avatar
Thank you for your response. I have read that 4crawler article, but which contacts are needed? I presume the A contacts are needed x2, no?
Old May 19, 2013 | 06:51 PM
BigWavePaul's Avatar
A + c
My 94 pickup starts like a champ now, after using 4Crawler's A and C points in the solenoid. Take the tire off to get at the thing, it's much easier. And, remove the steering stabilizer to pull the unit out. If you have enough lift, you may be able to remove the points without taking the starter out.
Old Nov 9, 2013 | 06:17 PM
Old Nov 10, 2013 | 01:22 AM
wyoming9's Avatar
Red face
Just curious why would you not at least check the brushes when your rebuilding the solenoid??
They do wear out
Longbed 90
Mar 11, 2019 12:38 PM
pickle6415
Oct 19, 2015 08:08 AM
Kylenicoll33
Sep 17, 2015 08:40 AM
--Oz--
Sep 6, 2015 01:06 AM
