Starter compatibility
Old Nov 13, 2018 | 03:34 PM
Neddita's Avatar
I have a 94 Pickup 4X4 with 5sp R150F transmission. At some point in the past someone put a 3.0L Mercedes turbo diesel in this truck. The original starter motor is not strong enough to start the truck in cold weather.
Does anyone know if starters from trucks with the 3.4L engines (4Runner, T100) will bolt up to the bellhousing. Or any other ideas....Thanks!!
Old Nov 13, 2018 | 05:11 PM
amamike91's Avatar
Does it have a block heater or glow plugs? Either one of those would help in cold weather.
Old Nov 13, 2018 | 06:56 PM
Neddita's Avatar
No Block heater, yes glow plugs but that's not the problem. This engine should start w/out a block heater down to single digits. The problem is that the starter motor isn't spinning the engine fast enough.
Thanks for the thought.
Old Nov 15, 2018 | 11:34 PM
ev13wt's Avatar
5 Year Member
A German engine won't start in cold weather with the oem starter.
I don't think so :p It gets really cold here.
Get out that Volt / Ohm meter. Run new wires and a new relay or install a relay. REplace starter contacts. Then recheck the system.
Bowelsmoving
Nov 14, 2018 09:25 AM
jwo
11
Dec 21, 2009 09:01 AM
redneckandy
Nov 17, 2009 05:25 PM
Stogieguy
Jul 28, 2007 10:41 PM
toyotablue
Nov 12, 2003 09:09 AM
