Stalls after 1/2 mile
Old Feb 6, 2010 | 09:00 PM
thedanned's Avatar
Originally Posted by mastacox
There's no way improperly gapped spark plugs caused the symptoms you have described, but it's good you got it running nonetheless. My guess would have been your fuel pump.
I agree
Originally Posted by jaredbishop
Ok let see. At the same time I did spray some throttle body cleaner in the throttle body, changed the air filter, and gaped the spark plugs. So it did stop. It also idles at about 500 rpms some times. most of the time it is about 950 rpms.
I think these things would account for your high readings at idle, especially if the gap on the plugs was huge and the filter was really clogged.
I say change your fuel filter. An engine uses more fuel when under load (moving the vehicle down the road) than when under no load (revving in neutral). Your fuel filter may have been clogged to the point of allowing enough fuel through to rev the engine under no load but not enough when the engine was working hard turning your transmission, t case, driveshaft, diff(s), axles, wheels, tires, and moving 2 tons of Yota down the road. Fuel filters are kinda pricey and can be a pain to replace but its good to cover your bases. EDIT: A weak fuel pump could cause this too.
The seafoam may have cleaned a little bit of crud out of your fuel filter, allowing more fuel flow. A partially clogged fuel filter could be the cause of the intermittent low idle you are experiencing now.
Just my two cents
Old Feb 7, 2010 | 05:33 AM
jaredbishop's Avatar
Well look what I found...
I opened one of the side compartments in the back and found 2 jacks and a fuel filter. Looks like the previous owner bought one but never installed it. score!
Old Mar 13, 2010 | 07:51 AM
chrisj345's Avatar
I have a first gen with a similar problem.
Mine will die when it gets warm. If I spray carb cleaner while it is thinking about dieing it will putter more for a second and then fire right back to running good. The good running only lasts about half a minute before it starts to putter again. I have used a lot of seafoam and will be draining my gas tank and changing the fuel filter and a few lines today.
Have you changed your fuel filter yet? Are your problems fixed?
the1998sr5
15
Jul 14, 2020 08:35 PM
_Nicco_
Aug 28, 2015 07:26 PM
ddg71
Jul 24, 2015 01:24 PM
Nailit69
Diesel Swaps
Jul 21, 2015 05:28 PM
Jnkml
Jul 6, 2015 01:20 PM
