Stalling when coming to a stop
Old Jan 21, 2013 | 12:21 PM
Chuck88's Avatar
Hello, this is my first post here. I have been searching and couldn't find anything that helped so i have to ask. Just bought a 1992 Toyota pickup ext. cab 3.0 v6 auto 4x4. Runs good, idles good, but after its warmed up and you come to a stop the engine stalls. Doesnt matter if your in drive or neutral. The only way i can stop it from dieing is either slow down very slowly before comeing to a stop or throw it in neutral and brake with my left foot and give it gas with my right. I should also say that its not dieing after you stop, it will die if your turning into a driveway halfway into turning. I pulled the tps,which i think i tested right, good. Also tested the air flow meter, also good. Someone has removed the egr and crimped the hoses, so i think it might be a vacuum hose not hooked up right. The throttle opener does not have a vacuum hose going to it and it runs at a lower idle with it hooked up, and dies just the same. Any thoughts?
Old Jan 21, 2013 | 04:31 PM
oldblue's Avatar
not sure about the vacuum hose not being connected there, but have you tried cleaning the throttle body and butterfly? this takes care of a lot of low idle and stalling issues at work for me. just a thought.
Old Jan 21, 2013 | 04:36 PM
Chuck88's Avatar
Yea i will give that a shot. Thanks. I forgot to mention too that it does not have a CEL. either the bulb is gone or has a short in it as it does not come on when you turn the key.
Old Jan 22, 2013 | 02:31 PM
Co_94_PU's Avatar
Clean and test the DASH-Pot. Also search for "Idle speeed control valve" or "ISCV", and read up on them.
Old Jan 22, 2013 | 04:42 PM
Chuck88's Avatar
Thanks Co, will give that a shot.
Charecter1
Nov 6, 2023 10:08 AM
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
jackiebrownia
Jul 20, 2015 09:02 AM
Jnkml
Jul 6, 2015 01:20 PM
