stalling problem.
Old Nov 3, 2008 | 06:10 PM
92yotaman's Avatar
stalling problem.
ok my 92 pickup has a 22re, the problem is that when im using a lot of electronics it stalls. Like when i have the lights on then i cant turn the heat fan all the way up or it starts to jump and sputter. On hills it cant even go up, and when i stop and keep it idling; if i put the windows up, when they get to the top, it will stall the motor. So i was thinking, maybe the alternator is old and sucks, or maybe something isnt grounded right. Im lost
Old Nov 3, 2008 | 06:18 PM
iamsuperbleeder's Avatar
give er some gas then; problem solved
no seriously, you might just want to have the alt tested
what are you idling at with no draw on the system? RPM and voltage wise...
Old Nov 5, 2008 | 10:10 AM
92yotaman's Avatar
more gas doesnt help. i think it might be the alternator, but i idling around 1500, but still have plenty of amps
Old Nov 10, 2008 | 12:56 PM
92yotaman's Avatar
bump... any ideas
Old Nov 10, 2008 | 12:59 PM
904_runner's Avatar
I think you are idling way too high. I idle at 800 rpms.
Old Nov 11, 2008 | 09:51 PM
Bill54880's Avatar
Sounds like a weak alt causing poor spark when its over drawn. Check the spark when it happens. Spark should be bright blue not yellow or white.
Old Nov 13, 2008 | 11:50 AM
92yotaman's Avatar
thanks the alt seems to be a good suspect
Steven.m.paulk
Jun 7, 2020 10:45 AM
Kamaloha
Oct 16, 2015 05:13 PM
alexcarey
Oct 14, 2015 06:05 PM
charlie_fong
Sep 27, 2015 10:06 PM
taraf
Sep 25, 2015 02:57 PM
