Speedometer quit
Old Mar 12, 2019 | 10:56 AM
fountain's Avatar
Speedometer quit
How do you tell if it's the cluster or the speed sensor? It's always had an issue with the speedo flipping back and forth when I turn the turn signals on, but now its completely quit. It did the fluttering deal for a few days and now its completely dead.
Old Mar 12, 2019 | 11:17 AM
scope103's Avatar
I assume you've already determined that you HAVE a VSS1 speed sensor in the back of the transfer case (in the olden days, the speedometer was cable driven, VSS1 was in the Combination Meter (cluster), and the speedometer itself was entirely mechanical). You can find the procedure for testing the sensor here: http://web.archive.org/web/200901240...e/combinat.pdf
Back when my sensor went south, I worked out that procedure without the help of the manual, but I checked it in the other direction. I hooked a signal generator to the disconnected lead from the sensor, and confirmed the speedometer worked when fed a simulated signal. I doubt you have a signal generator.
Old Mar 12, 2019 | 12:59 PM
dropzone's Avatar
Fossilized
what year is your 3rd Gen?
Thought some of the early ones, maybe 89-90 had mechanical speedo's
Old Mar 12, 2019 | 01:32 PM
scope103's Avatar
The '93 FSM still describes the mechanical speedometer, so I don't think it is as simple as model year. I've never been able to discern a pattern, though.
Old Mar 12, 2019 | 05:37 PM
fountain's Avatar
Mine is a 94. I assumed it had a speed sensor....and we all know how that goes. I'll check for one tomorrow
Old Apr 9, 2020 | 06:24 AM
fountain's Avatar
Anyone know the exact part number for the speed sensor...94 truck, 22re manual ,4x4
Old Apr 9, 2020 | 06:37 AM
fountain's Avatar
I just went and pulled the sensor out to look at it. It has the plastic gear on the end. I'm seeing multiple options for sensors when it comes to replacing. I see them from $33 to $160. Which one do I need?
Old Apr 9, 2020 | 06:41 AM
fountain's Avatar
83181-35051, 8318135051, 83181-35080
Here are some part numbers i found for one sensor that says it fits 94-97 Previa, 92-95 4-Runner and 92-95 pickup
Old Apr 9, 2020 | 02:48 PM
Paul H.'s Avatar
When mine went out troubleshooting pointed to the sensor but it turned out to be the speedo itself. Cost me $400 to get it replaced. That was 20 years ago though.
Old Apr 9, 2020 | 07:20 PM
fountain's Avatar
It sounds like a pretty expensive little part. It bounced on and off for a long time. Some days it would work, some it would bounce up and down and others it may not work. Finally it just stopped all together.
finding that part is seeming tougher than I figured.
Old Apr 10, 2020 | 06:03 AM
scope103's Avatar
Do you have the current part out? RockAuto has photographs of most of the options. They are distinct enough that you should be able to pick out the one that matches yours from the photos.
I look up a lot of part numbers, and I've never been able to figure out systematically which part number speed sensor matches to which VIN vehicle. You might be able to find someone who could do that at a dealership.
"Bounce on then off" was the symptom I had. OEM these run about $400, but RockAuto has them in the $110-$190 range. (Don't lose the gear; the sensor comes without it.)
Old Apr 12, 2020 | 05:53 PM
coopster's Avatar
From: exo-reality -wave if you see me; Front Range, CO
I think I would verify the wires from the speed sensor (signal generator really). Even with out a signal generator, I would at least test continuity from the combo meter down to the connector. Also check for shorts, and check for int'mittent opens by maybe having someone wiggle harness for you. A meter with 'continuity' tone would be real helpful.
I could not determine what year yours is?
Pardon my rambling; I am in process of converting my 95 (build date Oct) with a mechanical cable that goes into the cluster. I am converting to a manual tranny, from a 94 (also a 3VZ). It had the 'electronic' sensor/generator on the output shaft. That sensor has three wires; power, ground, and the signal. I have routed them (into the wire harness) up to the cluster. I am also changing the combo meter to the 94. I stumbled on all this chasing the need for SP signal into ECM.
The 95 has a cable, and its electrical converter is on the back of the combo meter. But I also just don't want to deal with a broken or noisy cable in the future.
924runner4wd
Apr 2, 2015 03:09 PM
RevJoE
Feb 9, 2015 02:08 PM
eleazar1
Jan 2, 2015 01:10 PM
green tacoma
Jun 20, 2014 06:59 AM
rena
19
Oct 26, 2004 07:19 AM
