speedo off
Old Jan 15, 2011 | 08:39 AM
thralldad's Avatar
speedo off
I mean speedometer!! This may be a dumb question but...
The only thing non stock on my 4runner are the rims (dealer installed in 86) and my tires are 235/75-15 instead of 225/75-15. The speedo reads 62 when GPS or radar indicates 55.
Will I need a taller tire to make my speedo more accurate? Thanks!
Old Jan 15, 2011 | 09:18 AM
INFINITY's Avatar
yup sounds right. might have aftermarket gears in it. other than that good luck
Old Jan 15, 2011 | 09:23 AM
MudHippy's Avatar
That's wierd huh? Nearly stock and the speedo's nowhere near accurate. Mine was reading a little slow when I had 4.10s and 35s. Put 4.30s in and now it's just about right on. Which makes no sense either. Because my truck had 4.10s and 225/75s stock. It should have taken something like 4.88s or 5.29s to make the speedometer accurate, according to popular opinion, but it didn't.
So, yeah, taller tires or taller gears.
Old Jan 16, 2011 | 11:12 PM
yeehaw1's Avatar
I have a similar problem, onLY with my truck I put 16" rims of a 200? (I think) Tacoma with 265/75/16s and my truck will be running about 67 when the speedometer reads 60. Any easy way to fix this? I've learned to deal with it if there ain't, or I could always go back to one of my 4 sets of 15" rims
Old Jan 19, 2011 | 09:51 AM
BMcEL's Avatar
Ok, I'll say it. Rim size has NOTHING to do with your speedometer being off. Only the tires and/or different gears can change that. Geez.
Old Jan 19, 2011 | 02:18 PM
yeehaw1's Avatar
ah, did i forget to mention that i went up from a 235/75/15 tire?
and im sorry buddy but ask any tire shop, rim size does make a differnce.
Old Jan 20, 2011 | 11:42 AM
BMcEL's Avatar
Talking
Yes, you did forget to mention the change in tire size...
You could run 31x10.50x15s and then swap to 31x10.50x20s and it would have absolutely ZERO affect on the speedometer. This is because both sets of tires are 31" tall. Tire size affects speedometer accuracy, rim size does not. If you want to argue that, all I can say is wow.
Dieselmann
Feb 19, 2019 02:57 AM
charlie_fong
Sep 27, 2015 10:06 PM
travisamorgan
Sep 2, 2015 01:00 PM
94ofCanada
Aug 14, 2015 06:37 AM
Pedalpwr27
Aug 13, 2015 06:37 AM
