Special Service Campaign for 90-95 4Runners, 89-95 Trucks and 93-98 T100s
Old Sep 20, 2006 | 08:52 AM
  #361
jacumja's Avatar
my 95 went in for service, which I couldnt afford at the time and they replaced the steering rod and gave me an alignment for free, Gene Reed in North Charleston, south carolina.
Old Sep 21, 2006 | 05:57 PM
  #362
toyotaoffroad91's Avatar
well got mine doen today i got the rod and all new tierods, and an alignment but i noticed they didnt do cam/caster oh well cant win them all. bespart was they said my steering stops were worn and if id like it would cost 102 bucks...hahah
Old Sep 29, 2006 | 04:58 AM
  #363
Tin Tin's Avatar
Toyota recall
Yeah i received a letter in the mail about my other 1990 4-runner qualifying it for the recall. Just call your local dealership and they will advise you what to do. I didn't do anything cause the engine on my 90 is shot and they won't accept my 92 hilux.
Old Oct 4, 2006 | 05:07 PM
  #364
BeaterToyota's Avatar
Here was my experience getting my '94 truck taken care of:
Called the dealer at about 5:00 on Monday when I got home from work.
They told me they could do it tomorrow, so I went and dropped it off that night.
They called me at lunchtime on Tuesday to tell me it was done.
I picked it up and they didn't charge me a dime or recommend a single other service.
They replaced the relay rod, tie rods (both sides), and all four tie rod ends.
This was at Miller Toyota in Manassas, VA. It couldn't have been any easier.
Old Oct 6, 2006 | 08:36 AM
  #365
YotaPower's Avatar
Originally Posted by arjan
It looks to be all the vehicles with the torsion bar setup after and including '89.
Newer Toyotas with the rack and pinions setup doesn't seem affected.
This sounds about right.
I actually had my 2in. sus. lifted '93 4WD Pickup at the dealer for a radiator and they swapped out the steering bar too on the recall.
I'm not sure what's it's called, but it's the one that has the stabilizer connected to it and goes all the way across. Never had any problems before, but new, free parts are always nice.
Old Oct 9, 2006 | 12:28 PM
  #366
netemcee's Avatar
Avoid Toyota of Oxnard, California, they misdiagnosed an electrical problem I had them check on at the same time, recommended $1000 of unnecessary work, and didn't do the tie rod ends, and didn't provide a full alignment. Never again!!!
Old Oct 15, 2006 | 09:12 PM
  #367
knavarro's Avatar
yea i just took my 93- 4runner and my 90 pickup they were both recalled
Old Oct 23, 2006 | 06:14 AM
  #368
spudrunner's Avatar
Just dropped my '91 4 runner off at the stealer, they said about 5 hours to do the job. Asked if they could give me a carfax report on the truck. They said yes for $20.00. I said I could do it myself for that and being a dealer I'm sure they pay a flat rate subscription and when I asked him they said yes but it would still cost me $20.00. They made sure they had the right phone # to contact me 3 times!!! So I'm sure I'll need a lot of extra work done (lol).:pat: LET YOU KNOW WHAT HAPPENS! Just a word of thanks to the forum 'cause I wouldn't have known about the recall otherwise.
Old Oct 23, 2006 | 10:38 AM
  #369
tc's Avatar
tc
Be sure to read the entire thread to be aware of what they might try to hit you with and how to deal with it!
Old Oct 23, 2006 | 01:10 PM
  #370
spudrunner's Avatar
OK, here's the poop, said the front end is fine, did alignment. Bad news, said front brakes need replaced(knew that), oil leak at oil cooler they said bad O- rings, knew I had an oil leak somewhere and they recommended replacing the timing belt, truck has 186,000 belt was replaced at 113,000. They want $680 to do all the work. If they don't do it I'll have to do it so I told them to go ahead. Doesn't seem like a bad price from the stealer but I could be wrong. Damnit I knew I'd have to pony up some dough. Just bought this truck like 3 weeks ago. It's in good shape inside and out cosmetically. Plus it's paid for so I'll just pretend I've got 2 more payments and paying it off early (lol). My '88 runner is much kinder to my wallet!!!
Old Oct 27, 2006 | 12:23 PM
  #371
JDDinWV's Avatar
Talking RECALL done on both my trucks
My 89 and 95 trucks have had the recall already done. They replace the whole bar that the tie rods and idler arm hook to. This steering arm is about 4 ft long. My 95 was bought with this part broken. They do brake. It lets the steering wheel turn freely from one of the wheels. The one on mine broke at a dead stop in a parking lot and was towed, where I bought it for next to nothing and had toyota fix it for free! The dealership replaced $400 in parts and alligned my 89 for free. It's rusted out and has 300k miles! they never blinked an eye.
Old Nov 2, 2006 | 09:12 AM
  #372
BlackToySteve's Avatar
Which dealer did you go to? I'm trying to choose between Parker, Appleway, or Downtown in Spokane. I bought my previous truck from Parker and have always been happy with them and their service.
Old Nov 4, 2006 | 04:46 PM
  #373
jerbear's Avatar
I got my card in the mail for my 1991. Is there anyone out there who can reccomend a stealership in the Buffalo NY area? I have heard bad things about most of them and not much good about any of them. A push in the right direction is appreciated. Thanks in advance.
Old Nov 4, 2006 | 07:15 PM
  #374
spudrunner's Avatar
Steve, I went to Parker in Coeur d' Alene. They installed the steering rod and gave me a free alignment no charge of course. I needed front brakes so I let them do that turn rotors and pack bearings. They told me I was just over 70,000 since the last timing belt so I had them do that plus replace the water pump and thermostat since they were already in there and would charge me no labor for that. Had an oil leak on the o ring on my oil cooler so they replaced that and that's a pain in the a-- to get to. When they replaced the timing belt they noticed the crankshaft pulley was sloppy took it off and the keyway was all wallowed out bad (not good). Replaced the crank pulley, new key of course and a new crank seal. They saved all the old parts for me so I could see for myself. Truck was there 2 days. Picked it up and it ran great/ drove great, no more slight pull to the right, and no more oil leaks. Labor $632.40 Parts $364.38. 12 month parts and labor guarrantee, unlimited mileage, that's right unlimited mileage! I may have saved some dough going to a shade tree mechanic but I think I got a fair shake. People there are very friendly and I believe pretty damn honest for a dealership, but this is still a pretty small town. If you decide to go there say you want to talk to Laurie Gold, she's great and a former Toyota mechanic.
Old Nov 5, 2006 | 02:48 PM
  #375
Steve, I went to Parker in Coeur d' Alene. They installed the steering rod and gave me a free alignment no charge of course. People there are very friendly and I believe pretty damn honest for a dealership, but this is still a pretty small town. If you decide to go there say you want to talk to Laurie Gold, she's great and a former Toyota mechanic.
Thanks spudrunner, that would be what I would expect out of them. I think I'll avoid Appleway at all costs and call Downtown or Parker for the fix. I think my T needs it with the bigger tires and locker in the front.
Old Dec 2, 2006 | 06:08 PM
  #376
toyota_mdt_tech's Avatar
Originally Posted by ASU4runner
I wonder which rod they're referring to....
Its the relay rod, its from 1989 to 1995 trucks, 1990 to 1995 4Runners and all T-100's. But this is only for 4WD rigs, it doesnt apply to 2WD's
Old Dec 21, 2006 | 02:30 PM
  #377
Th3duke's Avatar
For the Canadian Toyota Owners, if you call the 1-800 US number they will say you that you are not affected!
You must call the Canadian Toyota Headquarters.
The Number is: 1-888-869-6828
Turns out that my vehicle is affected...
Old Dec 28, 2006 | 05:43 PM
  #378
Pittman's Avatar
VO6 Special Service Campaign
Yesterday the head gasket blew on my '92 Toyota Pickup and have been researching the internet for a possible recall. I have read some postings for such a recall as early as 01/06 but it sounds that it may have ended. I contacted my local dealership and they told me that only head gasket recall is for the '98 model only.
The recall has never been completed on my truck as far as I know. Can anyone provide with some insight of who to contact, recall exp. and recommendations of what to do? Thanks.
Old Dec 28, 2006 | 08:10 PM
  #379
token7888's Avatar
Pittman
Pittman,
Don't know what motor you have, etc... but just do a search for the head gasket recall and the steering relay rod recall (50 N?) on this site. The relay rod is more recent and Toyota should have sent a notice to you if you are affected. There have been more than a few threads about both recalls and people's experiences.
I have had both done on my '92 4Run 3.slow 4wd.
Only problem I had was that they could not set toe on my runner due to seized tie rods ends.
Good luck,
J
Old Dec 28, 2006 | 09:43 PM
  #380
Yes, if you have the 3.0 and an open recall, (VO6) it will be fixed. But you need to call a warranty clerk and have them run the VIN to see if there is an open racall. Or, PM me your VIN and I will run it to see if its still open. If its been done, its closed, but who knows. Dealer said 98 only??? Stange as the 98 never had a headgasket recall of any kind!
