Sources/ideas for starter heat shield? (22RE)
Old Jul 16, 2009 | 10:19 AM
qdude79's Avatar
Mine is fairly new, works great, only gives problems after wandering around town in 108 deg heat. Not interested in new starter, just want to get what I'm confident is the problem, heat.
Anyone have a source for an aftermarket? Maybe ideas on fabbing my own??
TIA
Old Jul 16, 2009 | 10:32 AM
DeathCougar's Avatar
The starter and exhaust are on opposite sides of the truck, what good would a heat shield on the starter do?
Old Jul 16, 2009 | 10:41 AM
qdude79's Avatar
I was thinking reduce heat soak from the block...
Old Jul 16, 2009 | 10:47 AM
4Crawler's Avatar
Since the starter is bolted to the block/bell housing, it'll conduct heat to and and away from the starter even with a heat shield. JC Whitney sells a starter heat wrap kit you could try, but you might see if you can find out why the starter acts up in the heat. Do the test below cold and hot and see if there is any difference:
- http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
My original '85 starter cranks just fine even after crawling all day in Death Valley in 100+ heat.
Old Jul 16, 2009 | 10:53 AM
Same here. I have never had a problem with my starter (knock on wood) nor ever had a need for a heat shield. The block doesn't get hot enough to warrant it.
Old Jul 16, 2009 | 10:54 AM
qdude79's Avatar
It ONLY happens when very hot. Guess it's just a weak starter...
Old Jul 16, 2009 | 04:32 PM
TORTIS's Avatar
You could try running a relay. It cured my problems, and it is pretty cheap fix. I replaced the contacts in the starter, but still had problems till I did the relay. However good luck........
clok
Aug 1, 2015 09:42 PM
Dakotaneu
Jul 27, 2015 12:03 AM
PlayAwhile
Jul 20, 2015 11:36 AM
ZONAYODA
Jul 13, 2015 07:17 PM
colinmil
Jul 6, 2015 04:03 PM
