so i just bought this '92 4runner, but....
i bought this truck 3 weeks ago from this guy and i've had crap ever since. it started out throwing 3 codes, 25(air/fuel lean), 42(speed sensor), and 52(knock sensor). ok, i know most of the time the sensors are not bad, it;s something making them throw that code. guys, this truck runs like crap! chugging, backfiring, no power at all, spits and sputters. so, i check for vacuum leaks, none. put a complete tune up on it, no change. i take it to this guy that is highly recommended, he says my timing is off(thought of that already), it has one cylinder with low compression, and lots of carbon build up. so, i leave it with him over night. he calls me up, "your truck is 100%, runs like brand new. i reset your timing, made a few adjustments, she's good to go. perfect." i get there, same truck, same issues. i pay him for adjusting the timing, but now it has less power, chugs worse, backfires even when it's sitting in the driveway idling, got one heck of a dead miss. i don't know what truck he drove that was perfect, but it sure wasn't this one. guys i need some advice bad! i can't keep driving it like this, and i'm tired of getting jacked round by these mechanics. help!
compression was low on only one cylinder, i think he said 60 on that one.
could i still need an o2 even if its not throwing a code for it? i put lucas in the tank
if it has low compression on one cylinder then you def have a headgasket issue which could cause your backfire issue, start at the knock sensor and see if it runes better, check your cat and see ifs its plugged and change the o2 sensor, if still rusn like crap then plan on a rebuild or a 3.4 swap, if this an auto or manual trans?
Lot's of Water or steam out tail pipe , Loosing radiator fluid or coming out overflow = head gasket.
If not could be bent valve or need a valve adjustment.
I would check these thing's first before spending money on any part's. If you only have 60 something's going on.
Your compression should be about 160.
If you got it cheap enough and it's worth it to you, keep your eyes peeled for a wrecked truck/4runner. I found a low mile 3.0 from a truck w/a bent frame for $600, pulled it and did a swap, easy enough to do w basic tools and a hoist. Probably easier and maybe cheaper than doing a head/gasket job on a problem motor.
If it's in your budget... do a 3.4 swap, everyone seems to love them.
check valve adjustment.
if good,
do a leak down test. listen for air noise in intake or exhaust.
you can also try some mavel mystery oil soak on the low cylinder. for stuck rings
read this,
https://www.yotatech.com/forums/f2/s...y-work-243376/
if all else fails buy a wreck and go (research) 3.4 swap, best long term (more expensive option).
if good,
read this,
all these symptons will make it run like junk, knock sensor will retard the timing and kill all your power, even when i had 488 and 33s with a code 52 i had no power at all.
this would be one part of your big problem, id look into a new motor.
So in other words you pretty much got what you paid for!!
You took a chance and you lost this one.
I hope the rest of the vehicle is in good shape with that much mileage on.
Time to decide keep this one for spare parts and find a good running one to drive..
i myself would not put any money in this engine because I am not a big fan of the 3.0.
No matter what you do that low compression is not going to be cheap to fix unless you can do all the labor yourself.
Could be bad valves could be rings could be headgasket just bleeding into the next cylinder.
Not to mention all the other issues!!
Good luck.
Good luck.
