snow plow for 88 2WD Toyota pickup
Old Mar 14, 2007 | 09:15 PM
kevin777's Avatar
I am looking for a snow plow for a 1988 Toyota 2WD pickup. I found a company that has them for 1989-1995 2WD Toyota pickups. I thought the frames were the same for 1988 and 1989 models. Can someone explain if there really is a difference?
thanks
Old Mar 14, 2007 | 09:25 PM
DeathCougar's Avatar
There are some differences in the frames, especailly the way the front buymper mounts. Likely, the 89 style are setup for side mount, where the 88 has front mount bumper brackets, among other things.
Old Mar 15, 2007 | 06:52 AM
kevin777's Avatar
thanks!
Old Mar 15, 2007 | 07:10 AM
MMA_Alex's Avatar
you're going to plow with a 2wd? good luck, and buy lots of sand for the bed
Old Mar 15, 2007 | 08:44 AM
TNRabbit's Avatar
I was going to say the same thing; I don't think a 2WD would be worth two ˟˟˟˟˟˟ with a plow...
Old Mar 15, 2007 | 09:37 AM
mtrdrms's Avatar
A good locker and some wieght. It might work
Old Mar 15, 2007 | 02:31 PM
ShortyzKustomz's Avatar
My 2wd Nissan doesnt move in the snow, My 2wd Isuzu did great cause it was an underpowered POS so it could hardly spin. My dads FS Chevy 2wd is bad in the snow too
Old Mar 15, 2007 | 05:12 PM
MMA_Alex's Avatar
my p/u doesn't like snow in 2wd. If i park along the street with the right tire in the patch they dont plow i cant backup without putting in in 4. I also cant back into my driveway (slight uphill) in 2wd. I personally wouldn't even bother. If you need a plow truck look by the sides of the road this spring, and im sure you can find a beat up f-150, or silverado with a plow for $1500 or less.
Old Mar 15, 2007 | 05:29 PM
runner4thebeat's Avatar
or you could just sell ur truck and buy this
http://cgi.ebay.com/ebaymotors/Toyot...spagenameZWDVW
Old Mar 15, 2007 | 07:23 PM
sndptpilot's Avatar
The plow mount on my 89' 4x4 attaches to the frame rails at the tow hook bolts and the hole behind them. I don't think there is a difference there between the years or 2x to 4x. Its going to be pretty low though.
Old Mar 16, 2007 | 05:17 AM
Brenjen's Avatar
I don't know how a Toyota 2wd does in snow, but each vehicle I've ever driven has been different. My wifes BroncoII won't move an inch in 2wd but is one of the best in 4wd. My old '90 Dodge ram goes like a snowshoe rabbit & it's only a 2wd, granted it's heavy & it has a sure grip rear end & really aggressive tires.
I think if you have a good set of tires or chains & weight in the back on top of a locker it'll probably work; a 4wd would be better though.
bigblue82
10
Jul 6, 2015 08:27 AM
Wid
Jul 1, 2015 11:54 AM
paxanders
Jun 21, 2015 06:29 AM
infinityisfive
Jun 16, 2015 06:51 PM
