snapped new timing chain
Old Sep 16, 2013 | 01:41 PM
mc360's Avatar
hey thanks for the pictures, very helpful. this is the picture i was going off of
IMG_4421.jpg?t=1179369650
Old Sep 17, 2013 | 05:43 PM
mc360's Avatar
ok so im pretty stumped on this here is a video i made, i thought maybe i was off a tooth on the cam but it looks right to me what about you guys?
Old Sep 17, 2013 | 05:46 PM
Kiroshu's Avatar
Still no start..?
I assumed you verified and correcting timing chain timing marks.
The Camshaft sprocket in your video is dead on.
Does the Rotor button point to #1 cyldiner on the distributor cap exactly..?
If not reposition distributor drive gear until it does so.
Old Sep 17, 2013 | 05:51 PM
mc360's Avatar
sorry about the video idk why it uploaded upside down. it starts but where i have the distributor now it had to be fully advanced to start (with gas pedal being pushed) and the timing light shows it at like 15 degrees btdc. if i pull the distributor and rotate the rotor either clockwise or ccw it wont start with the housing fully advanced or retarded
Old Sep 17, 2013 | 05:53 PM
  #25
Kiroshu's Avatar
Engine at TDC #1 cyldiner. Distributor rotor button should be pointing at #1 cylinder on the distributor cap.
Old Sep 17, 2013 | 06:35 PM
  #26
mc360's Avatar
when i pull the distributor off and move it a tooth forward or backwards it to far either way to where it wont start
Old Sep 17, 2013 | 06:49 PM
  #27
Kiroshu's Avatar
Old Sep 17, 2013 | 06:57 PM
  #28
mc360's Avatar
this is where it is at
Old Sep 17, 2013 | 07:26 PM
  #29
Kiroshu's Avatar
Is the crank shaft at TDC along with the camshaft...?
Crankshaft at TDC #1 cyldiner.
"Notch" on crank pulley/vibration damper pointing at 0*...?
Cam and crank must match TDC together or the engine will not operate properly.
It seems like your distributor is still installed incorrectly to the engine being at true TDC.
Seems like you have the distributor installed at TDC for the camshaft when the crank shaft is not at TDC. (Which I believe would be #1 cyl's exhaust stroke.)
Line them up together and re-install distributor.
Old Sep 17, 2013 | 07:36 PM
  #30
mc360's Avatar
The video shows the crank at 0 on the timing mark and you said the cam was dead on
Old Sep 17, 2013 | 07:40 PM
  #31
Kiroshu's Avatar
Oh missed that part in the video ^_^ I see it now though.
Old Sep 17, 2013 | 07:43 PM
  #32
mc360's Avatar
So what is your guess, it wont idle since i changed the timing chain and i had to advance the distributor so much that it pings under load
Old Sep 17, 2013 | 07:44 PM
  #33
Kiroshu's Avatar
Stopping the video at 0:11 shows the camshaft on #1 cyldiner on the exhaust stroke.
You can see the lobe lifting up the rocker arm opening the exhaust valve.
Old Sep 17, 2013 | 07:47 PM
  #34
Kiroshu's Avatar
Actually.
I wonder if I can zoom in the video. I think its ok as far as that.
Old Sep 17, 2013 | 07:49 PM
  #35
Kiroshu's Avatar
Yea never mind I zoomed in on it. For second I swore the lobe was pointing up on the camshaft.
Old Sep 17, 2013 | 07:51 PM
  #36
Kiroshu's Avatar
Very interesting. The way you describe it.. it sounds heavily like the distributor timing.
Old Sep 17, 2013 | 07:54 PM
  #37
Kiroshu's Avatar
May not be a timing problem at this point. Seems everything is in order.
You received the truck with it not running correct...?
Possibly restricted exhaust system..?
Compression...?
Vacuum gauge..? (Verify internal engine health.)
Spark plug gap..?
Old Sep 17, 2013 | 08:36 PM
  #38
mc360's Avatar
I bought the 4runner running but knowing it needed a timing chain, i just replaced the cap rotor plug wires and plugs with ngk Bpr5ey (assume they are oem so i bought some new ones) the gap is what ever those plugs come with stock.
I dont know the compression since i dont have a compression tester vacuum gauge or air compressor
Old Sep 17, 2013 | 08:55 PM
  #39
Kiroshu's Avatar
Ignition Cables(Wires) Distributor cap installed correctly...?
Old Sep 17, 2013 | 09:04 PM
  #40
mc360's Avatar
Yes i pulled one wire off at a time and replaced it before i moved to the next, but i will recheck
