Sloppy Steering help
Old Jan 23, 2019 | 11:38 AM
old87yota's Avatar
Good information, akwheeler.
Does the Factory Repair Manual state how much play there should be?
I just remember seeing a maximum allowable number and "tighten and make sure steering does not bind" statement, but not a normal free play number.
Old Jan 23, 2019 | 02:56 PM
akwheeler's Avatar
I no longer have access to the manual, I am old school, adjust by touch, bionic torque wrench implant in my elbow and highly tuned assometer. I only go looking for specs when rebuilding engines or differentials and the like. It may be luck but I haven't stripped a bolt or had anything wiggle loose in over 20 years.
Old Jan 23, 2019 | 04:49 PM
scope103's Avatar
... Does the Factory Repair Manual state how much play there should be? ...
Of course. http://personal.utulsa.edu:80/~natha...nce/2maint.pdf
30mm (on the edge of the steering wheel) with "light finger pressure."
Old Jan 24, 2019 | 01:37 AM
ev13wt's Avatar
5 Year Member
So an inch is "tighter" than spec. Nice.
Old Feb 21, 2019 | 10:29 AM
  #25
GrandPrix's Avatar
Steering gear, front wheel bearings, shocks, and steering damper all replaced. Steering and handling is spot on now.
