Should I? (Rust Related)
Old Sep 29, 2009 | 06:50 AM
  #101
BoostinChick's Avatar
Originally Posted by pwd
@turboboost Yes sir, thats more like the rust I'm used to seeing. Do you plan on doing the necessary bodywork on that?
Great thread, its give me the confidence that I can get fix up some body rust on my truck/runner.
So what supplies has everyone used (that mesh stuff and Bondo)?
I actually cut at the seam in the rear as I suggested in my original post. I am going to my buddy's fab shop to get a panel welded underneath to close it up. As for the other rust holes I cut out a bit larger than the actual rust area to make sure I was cutting into bare metal. From there I am either going to cut a piece of metal to pattern and use 3M bonding adhesive, or have my friend patch it in there with his welder. From there I will either use Tiger Hair or Bondo to cover the imperfections and coat it with bed liner.
Old Sep 29, 2009 | 06:59 AM
  #102
92 TOY's Avatar
pics?
was wondering how you were making out with it.
Old Sep 29, 2009 | 08:55 AM
  #103
Been raining here the past couple of days and I have not made it to the fab shop yet to get the panels done. Once I get er' going I will post up pics.
Old Sep 29, 2009 | 08:59 AM
  #104
92 TOY's Avatar
i hear ya!
it's cold and windy as anything up here and i don't feel like doing anything.
Old Sep 29, 2009 | 02:16 PM
  #105
sb5walker's Avatar
As others have said, POR-15 is not a rust "killer", but a really good sealant. Treating with a phosphoric acid-based rust remover or a tannic acid-based rust converter should be done first. Then a topcoat with POR-15 or KBS RustSeal (if you use a remover) or a good chassis paint (if you use the recommended converter - Fertan).
From: http://www.toyotanation.com/forum/sh...11#post2799311 The OP wanted to clean up some rusty steel wheels:
Originally Posted by pickup
So, I never received an answer about how to clean them up. There is a little rust and pitting. I'm thinking Steel wool? But I don't know if how that will work.
Originally Posted by sb5walker
I've been wanting to write this up for a while, may as well be now. I learned about rust when I owned a 1964 Triumph TR4. For as long as I owned the car, I was engaged in a life-or-death battle with rust. I learned a lot - mostly what doesn't work - as I experienced fun things like having a rear fender fall off while rounding a curve, and, even more fun, having the steering gearbox break free of the rotting frame, jamming the steering just as I entered a curve. Both I and the owner of the brand-new split rail fence I destroyed found that episode quite amusing. :rolleyes: Anyway, maybe this will help someone protect their truck:
There are two fairly effective ways to treat surface rust. I say fairly effective because nothing will work 100% or last forever. But you can knock it back pretty well.
The first approach is to use a "rust remover", also called a rust "dissolver". That's a phosphoric acid etching solution, sometimes with added ingredients. Naval Jelly and Ospho are probably the two most popular. You absolutely must cover the treated area with an impervious oxygen and moisture barrier, otherwise the rust will start up again quite soon, sometimes within hours.
The second is to use a "rust converter" which chemically reacts with iron oxide to produce a compound that inhibits further rust. By itself, a rust converter will last much longer than a rust remover by itself, but ultimately a converter also needs an impervious topcoat for the longest lasting effect. Originally, rust converters were based on phosphoric acid, since it reacts with iron to produce iron phosphate, which provides the steel some protection from further rust. The best converters now use tannic acid, which reacts to produce iron tannate - a much more durable rust preventative than iron phosphate.
Most people who have treated rust with removers or converters have found that they don't work for long on vehicles. The reason is salt. The salt ions actually chemically and electrically alter the steel to cause it to generate low voltage electricity that essentially does electro-plating in reverse: instead of depositing metal, the salt causes the metal to be electrically eroded. If steel has been in contact with road salt for an extended period, it is practically impossible to remove the chlorides from the steel, so even if you treat it with rust converter, the steel will still electrochemically corrode.
I actually did find a product that worked amazingly well on my old TR4 - for the surface rust. The problem was that by the time I found the product, most of the body and frame of my poor TR4 was shot through with rust, and when that happens, nuttin helps.
The product that worked quite well is "Fertan". It was developed for the British Navy, and it is used widely in the marine industry around the world. The reason Fertan works well is that it contains zinc. Zinc is electrically a more active "anode" than steel, and when in contact with steel it will sacrifice itself and protect the steel. Most ocean-going vessels have zinc clamped to the propeller shaft to protect the shaft and propeller from corrosion.
There's some info about Fertan here:
http://www.toyotanation.com/forum/sh...25#post2764125
Fertan is great for the frame/suspension, especially if it's top-coated with one of the chassis paints listed in the post linked above. (If the rust is inside the frame, you have an almost impossible challenge on your hands. About the best you can do is buy some time - IF you manage to somehow get the products inside the frame.)
BUT. The problem with Fertan is that it is somewhat "thick". It needs to be thick to provide a reservoir of zinc. For that reason, I'm not sure whether it would work for the inside of the wheel. I would worry that the surface would not be smooth enough to provide an air-tight seal for the tire.
So in your case, the rust remover/impervious topcoat approach might work better. Fortunately, there is a great remover that also contains zinc - and it probably would work well for those wheels. It's called "RustBlast" and it's made by KBS, a maker of coatings similar to (but I think better than) POR-15's product line. RustBlast is mainly phosphoric acid - it does dissolve rust like naval jelly or Ospho, but it also contains zinc phosphate that counteracts the chlorides that have infected the steel. It should be top-coated with KBS's "RustSeal" product or with POR-15. That provides a smooth, glossy, impervious finish that is very tough and also should provide a nice airtight seal for your tires.
Surface prep is everything, so you may want to sand the rusty areas smooth, clean and degrease the area with something like KBS's AquaKlean, then treat with RustBlast, and finish up with RustSeal. That's the best thing I can think of for those wheels.
http://www.kbs-coatings.com/Prep-Products_c_1-1-0.html
http://www.kbs-coatings.com/Rust-Sealer_c_2.html
http://www.kbs-coatings.com/KBS-Syst...-Kit_p_23.html
Oh yeah. I lost that life-or-death struggle with rust on the old Truimph. I learned that once rust has gone deep, nothing can stop the metal from returning to Mother Earth. I gave what was left of the car to another TR4 owner to use as a parts car. Too bad - that car had more "soul" than any vehicle I've ever driven.
From: http://www.toyotanation.com/forum/sh...25#post2764125
You could claw your way out of most anything with those bad boys - those are NICE! :thumbsup:
If fact, the whole truck is nice.
In the spirit of keeping it nice, here's a product to fight back against those Michigan winters and that salt-caused rust:
http://www.retro-uk.com/fertan.htm
http://www.fertan.de/katalog/english/katalog.htm
Where to order in the U.S.: http://www.fertanamerica.com/
Fertan is used by a lot of navies and commercial marines because it deals better with rust caused by salt - it has zinc in the mixture which helps neutralize the salt ions. It was the only product that made any difference on my rust bucket '64 Triumph TR4. It works best if you apply a topcoat after it's cured, with something like Eastman's Extreme Chassis Black, KBS BlackTop or POR-15's Chassis Coat Black
Old Nov 18, 2009 | 06:02 AM
  #106
Update -
Went to a local fab guy and showed him the truck. Waiting on the estimate now and will try to schedule something either before Thanksgiving or shortly thereafter. Will post pictures when all is said and done.
Swampwalker
Oct 12, 2015 09:49 AM
Obmi
Sep 10, 2015 03:36 AM
fabing455
Sep 7, 2015 08:08 AM
larrys93pickup
Sep 6, 2015 06:37 AM
