Shock options
Old Mar 1, 2009 | 02:36 PM
  #41
SMOD's Avatar
Originally Posted by Alex 400
if you leave the torsion bar crank with the bf spacers you will blow boots and or cvs very quickly, as SR5 found out. besides that, I think the 10" travel shock would work in the back. I have the 9" travel my 1.5" of leveling lift in the rear.
Here is downey's site link for shocks.
http://www.downeyoff-road.com/Suspen...Absorbers.html
You can't any way, but don't use the mv-12's in the front. they are way too soft and would dangerous. in the back they are fine, but in the front you need a little bit more firmness i think. I don't have experience with the DT prerunner shocks, but i would be interested to know how they are.
good luck.
You think 10" travel would work?
If you have a 1.5" lift and I have a 4 inch lift.. and you have 9" travel shocks... shouldn't I get a little longer?
I think I'll check out the DT's for up front, but for now I'm just going to get the rears now and wait on the fronts and just shim the stock front shocks until I can get more $$$$$.
Anyway..
You are helping a lot Alex, thanks for all the help so far.
Old Mar 1, 2009 | 02:39 PM
  #42
SMOD's Avatar
OoooO
On this site that you posted
I found the Pre-Runner DT's for my runner for the front with a 0-1.5" lift! And guess what! I have the 1.5" BJ spacers. lol. I'm pretty sure those would work up front. Right?
Thanks!
Old Mar 1, 2009 | 03:02 PM
  #43
Alex 400's Avatar
Originally Posted by SMOD
OoooO
Thanks!
That is what i was thinking. The DT mv-12's only come in an, 8, 9, 10, and 13 inch versions and with the 13 you would probably have no up travel or very little. I think a 10" would be ok, but i would wait for someone elses opinion before you buy. Downey recommends the 10" with their 3" lift kit. That is why i think it would work.
Old Mar 1, 2009 | 03:05 PM
  #44
SMOD's Avatar
Yeah, ok. I hope someone else jumps in! lol.
As for the front shocks those 0-1.5" lift pre-runner shocks would work? Right?
Thanks
Old Mar 1, 2009 | 03:11 PM
  #45
FredTJ's Avatar
It's really easy to figure out what length (compressed and extended) that you need.
Simply remove the shocks, one end (front or rear) at a time and cycle the suspension, measuring the distance between the shock mounting points with the axle fully stuffed and fully drooped.
There is no guessing at all now.
Simple as....
Fred
Old Mar 1, 2009 | 03:17 PM
  #46
SMOD's Avatar
Simple as....
Fred
Yeah, that sounds like a good idea huh.
I would have to put the LC coils on before I did that though. And that would cause me having to ride with no rear shocks for a while.
Would it work if I measured the stock shocks fully drooped and fully squished and then add 4 inches to that? Or does it not work that way?
Old Mar 1, 2009 | 03:18 PM
  #47
Alex 400's Avatar
Simple as....
Fred
That is true for leaf sprung, but is it true for coil sprung? the 4runner's coil sprung suspension uses the shocks as the droop limiter. THis could make it possible to have too long of a shock.
Old Mar 1, 2009 | 03:58 PM
  #48
SMOD's Avatar
So, on summitracing.com the Pro Comp shocks that are for a 4 inch lift for the rear have an extended length of 26.750 inches and a compressed length of 15.580 inches.
The MV-12s with the 10 inch travel have an extended length of 25 inches and a compressed length of 15 inches. It seem like they would work but I'm not totally sure??????
As for the 13 inch travel MV-12s they are too long.
Old Mar 1, 2009 | 05:38 PM
  #49
Alex 400's Avatar
you could go with a prerunner 8000 shock. they might be available in different lengths. You could call DT and talk to them about your options.
Old Mar 2, 2009 | 12:25 PM
  #50
SMOD's Avatar
I called Downey and talked to a sales rep and he said the MV-12s with the 10 inch travel will work with my rear lift.. so I ordered a pair of those!
I also ordered a pair of the prerunner shocks for up front!
Total was $245 with tax and s&h. Not too bad I think. I just hope they're worth it!
Old Mar 10, 2009 | 08:03 PM
  #51
SMOD's Avatar
So I got the shocks and was looking them over and they actually look like they were made sloppy.
The weld for the eyelet mount are not too good and it doesn't look like they took a lot of time painting them.
But other than that they seem and look pretty tough. tougher than the stock shocks for sure.
Old Mar 10, 2009 | 08:41 PM
  #52
Tubbyfatty's Avatar
did you install this yet?
Old Mar 10, 2009 | 10:53 PM
  #53
Alex 400's Avatar
mmhmm, i didn't notice any of that on mine. was that on both the fronts and the rears?
Old Mar 11, 2009 | 10:36 AM
  #54
SMOD's Avatar
Yeah, fronts and rears. I'm not saying that they're crappy, it's just what I noticed. I thought for $50 a piece they would have taken a little more time at production.
I haven't installed them yet so I don't know how well they perform yet, so I cant say they suck or anything.
Old Mar 11, 2009 | 11:19 AM
  #55
Alex 400's Avatar
yeah i can't say i noticed anything worse than the stock ones. My stock shocks were really toast. the posts on the tops of two my shocks were bent at where the post went into the body of the shock. I felt they were stronger pieces than the stock ones.
Old Mar 17, 2009 | 12:02 PM
  #56
SMOD's Avatar
I just put on my LC coils and the panhard bar drop bracket with my dad.. and we went to put the rear mv-12 shocks on and the eyelet bushing is too small.
Did you have the same problem Alex?
Old Mar 17, 2009 | 12:18 PM
  #57
waskillywabbit's Avatar
Press fit them in with a c clamp or vise.
Old Mar 17, 2009 | 12:44 PM
  #58
Alex 400's Avatar
yes, but they sent the correct bushings in the box with the shocks? did you order them from downey? they should have sent you extra bushings.
You could probably ream them out a little bit with a drill.
Old Mar 17, 2009 | 01:07 PM
  #59
SMOD's Avatar
Oh, I'm pretty sure that U didn't get extra bushings with them, but I will definitely double check.
I did order by phone from downey.
And I thought about drilling them out a bit but I don't have a big enough drill bit. lol. Anyway before I go buy a drill bit I'm gunna check to see if there are any other bushings that came with them.
Also, I think I'd want the right bushings so maybe I'll call downey.
Old Mar 17, 2009 | 03:55 PM
  #60
Alex 400's Avatar
take the shock up to a parts store, they might have them. They are energy performance bushings. I saw them at a 4 wheel parts when i went up there.
