Shackles installed!!!!
Old Feb 14, 2010 | 05:15 PM
blueyota38's Avatar
I today bought the $20 lift shackles from autozone. Was kinda iffy bout them atfirst but i am fully satisfied now that they are installed. They gave me about 1.5in in the rear of my truck an got my leaf spring off my exaust tip!(used to get wedged between spring and body when i would flex hardly at all!) Will post pics tomarrow! by the way put the shackles on the 3rd hole. Love toyota!
Old Feb 14, 2010 | 05:32 PM
iamsuperbleeder's Avatar
I had those installed once upon a time too...
I use to call them my "wtf shackles"
in the end, I ended up forking over the dough to WabFab for some real shackles
Old Feb 14, 2010 | 05:54 PM
blueyota38's Avatar
Yeah i just dont see spendin more money for basically the same thing! I have mine on the 3rd hole so it dont look wierd, an so i can get the lift i was looking for. Im really impressed. and installation was easy!!!!
Old Feb 14, 2010 | 06:07 PM
blueyota38's Avatar
heres some pics, not to good cause its night time but yeah. They look all shiney and new! hahaha
Old Feb 14, 2010 | 06:15 PM
874runnersr5's Avatar
But they arent the same thing... they are similar.. but are not the same. good aftermarkets include grease fittings, stronger plates... ect
myyota's Avatar
You might want to shoot some paint on them before they start rusting.
Old Feb 14, 2010 | 06:16 PM
myyota85's Avatar
thats what i did on my old 79 yota but had 2 step it up $ wise on the newer one.
Old Feb 14, 2010 | 06:19 PM
allnmstkn313's Avatar
Please say that those ARE NOT in fact grade 5 hardware store bolts...
Old Feb 14, 2010 | 07:04 PM
ptool2000's Avatar
Those look plain scary!
Old Feb 14, 2010 | 07:06 PM
Booosted Supra's Avatar
HOLY SHACKLES BATMAN! No seriously those things are junk, they bend like paper when put to the test and I give it about 5-10 real serious wheeling trips before your leaf springs are flattened out or bent, and yes they are most likely grade 5 because they most definitely do not come with 8's
Old Feb 15, 2010 | 12:37 PM
blueyota38's Avatar
ok here we go i said they were basically the same thing as other shackles, they serve the perpose, the bolts on mine are 6 grade, and for the offroading ill be doing they do exactly what i want! they got the leaf spring away from my exhaust an if it flattens my springs out i dont give a dern, there stock springs with ad a leafs! Can be replaced easily! Also trying to fit bigger tires!! So any other people want to bash me for saving some dough????
Old Feb 15, 2010 | 12:58 PM
No body is bashing you for being cheap, everyone is looking out for YOUR safety and the long term damage it will end up costing you on my truck, but if you want to take it as bashing then more power to you... not my junk
Old Feb 15, 2010 | 01:41 PM
RustBucket's Avatar
They're probably not too dangerous... What are they, about 1.5" x 0.25" x 8"? If so the compressive force at which they would buckle is 9000 lb. (http://en.wikipedia.org/wiki/Buckling)
However, if they are only 3/8" thick then that number goes down to 3800 lb!
Old Feb 15, 2010 | 02:02 PM
peow130's Avatar
yeah, 10" shackles that are 3/8" of an inch thick are an accident waiting to happen..
not to mention you just pointed your pinion nearly at your T-Case, so you're going to have u-joint problems pretty soon.
Old Feb 15, 2010 | 02:03 PM
Fink's Avatar
Nobody is bashing you man.
When you post pics and ideas on the web you open the air for the good and the bad.
If they do what you want them to then rock on.
I would definitely hit them with a little Rustoleum though.
Fink
Old Feb 15, 2010 | 02:05 PM
toy93ota's Avatar
Good call bleeder, what did the shackles from WabFab cost you?
Old Feb 15, 2010 | 02:10 PM
Fink's Avatar
Hijack much?
WabFab Shackles
Fink
Old Feb 15, 2010 | 02:41 PM
RustBucket's Avatar
Just a quick note about the bolts, grade 5 is basically equivalent to metric 8.8 (see pic of WabFab shackles - though WabFab's are much larger).
Old Feb 15, 2010 | 02:48 PM
blueyota38's Avatar
That dont make since rust bucket, 3/8 is bigger than 1/4? That would mean the buckell strength would go up instead of down!!! And i dont know what your talkin bout, my pinion pointin at my transfer case?
Old Feb 15, 2010 | 02:52 PM
RustBucket's Avatar
Whoops, I meant 3/16. Thanks for catching that!
