Second Blown HG on 3VZE: Desperate
Old Oct 12, 2009 | 05:37 PM
  #221
flashkl's Avatar
AnTiFreeze? lol
Old Oct 13, 2009 | 01:24 AM
  #222
TNRabbit's Avatar
ATF is Automatic Transmission Fluid~ lol x2
Old Oct 14, 2009 | 04:26 PM
  #223
buckz6319's Avatar
TNRabbit....sorry to here about your head gasket problem returning after a total rebuild that sucks!!.....I hope you take the time to make the right decision on doing a engine swap or putting more money into the 3vze....good luck!
Old Oct 15, 2009 | 01:44 AM
  #224
TNRabbit's Avatar
Did you even READ the thread?? Running well for the past 6,000 miles....
Old Oct 15, 2009 | 02:40 AM
  #225
buckz6319's Avatar
my bad TNRabbit....didn't read the entire thread.....not enough time to read all.....just really glad to here your running good!!
Old Sep 8, 2010 | 07:16 AM
  #226
TNRabbit's Avatar
UPDATE:
Just rolled over 250,000 miles; still running great! WOO-HOO~
Old Sep 8, 2010 | 10:39 AM
  #227
thook's Avatar
What? You've got 250k already on your rebuild?????
Oh....and, hello Gary! Long time no see!
Old Sep 8, 2010 | 10:59 AM
  #228
TNRabbit's Avatar
Hey, Matthew~
Loooooong time since I was on the forum; incredibly busy! I'm rackin' up the miles...
Old Sep 8, 2010 | 11:07 AM
  #229
thook's Avatar
Good grief........apparently so! I've only got about 8k on my 22re rebuild after 2yrs. But, then I don't drive everyday. Everything going well for you? PM, if you like, to answer that, eh.
Old Sep 8, 2010 | 02:01 PM
  #230
buckz6319's Avatar
TNRabbit.....sounds like you did a good job on your rebuild.....and it sounds like you could go another 250,000
Old Apr 26, 2012 | 02:14 AM
  #231
TNRabbit's Avatar
Just passed 270,000 miles.....still running well!
Old May 2, 2012 | 10:52 AM
  #232
Red Wagon's Avatar
Just read the whole thing. I hope I don't run into a fraction of your fun with my 3.0.
Old May 2, 2012 | 07:13 PM
  #233
TNRabbit's Avatar
Yes, but I learned a TON!!
I've since replaced the fuel pump, fuel pressure regulator, and distributor. The distributor & fuel pump made the most difference;lots more power under 2000 rpm.
I want to replace the VAFM, but at a DISCOUNTED price of over $600, that won't be happening any time soon....
Old May 2, 2012 | 10:17 PM
  #234
Red Wagon's Avatar
Are you still happy with the 3.0 after all that? If you could get all your money back would you have swapped an engine in hindsight?
Old May 3, 2012 | 02:43 AM
  #235
TNRabbit's Avatar
In hindsight, I would seriously consider a 3.4. I looked REALLY hard at a 1UZ swap but it was just too darned expensive & complicated.
Old Jan 30, 2013 | 05:19 AM
  #236
TNRabbit's Avatar
OK, took a road trip this past weekend (3 hours each way) to western MD & when I got back on Sunday, I noticed my idle was off. The engine was "rocking" like one cylinder wasn't hitting. I also noticed the same thing when accelerating from @ 1100 rpm in a higher gear. Otherwise, it's run good.
I checked the radiator this morning before starting her & I was down about a pint or so. The level has been rock solid for over a year now.
I fear the head gasket is on the one out again. I hope it's something else, but I pretty much know what it is at this point. I was running hard up pretty good sized mountains (70-80 mph uphill) on this trip, so I 'm sure the pressure of that is what did it. It's strange, because I've ragged the hell out of this engine since I got it going again without one issue.
Crap.
This couldn't come at a worse time. I've been unemployed for over a year now & barely scraping by.
Old Jan 30, 2013 | 12:24 PM
  #237
Red Wagon's Avatar
Sorry to hear that dude.
Have you thought about moving to find work?
I've moved cross country twice to find work. Go where the oil or mines are. It takes a bit to get your foot in the door but once you do you'll not be sorry.
Old Mar 16, 2013 | 09:44 PM
  #238
TNRabbit's Avatar
Turns out it's the #3 cylinder; when I unplug the spark plug wire to it, no change in idle. I'm going to pull the plug & see if it's something simple like a cracked insulator (hoping). If that's not it, I'll get my compression tester out & see what's going on. No more loss of coolant, so I'm hoping the shortage last time was just a one-off overflow or something.
To SMOKEJUMPER, I moved to VA & got a job within the first two weeks~ it doesn't start until April 15th, though.
I'll need another job to make ends meet, but after 14 months without a job, it's good to at least have an iron in the fire~ woo hoo!!
Maybe I'll get lucky with the engine, too, and it will only be a plug wire or spark plug....
Old Mar 17, 2013 | 08:11 AM
  #239
bone collector's Avatar
good luck with the job and the engine!
Old Mar 17, 2013 | 04:34 PM
  #240
TNRabbit's Avatar
I have good spark to that plug, so the problem is either a valve or injector. It's my only transportation right now, so will have to wait....
