Seat Belt Question
Old Feb 12, 2019 | 08:01 AM
mrgtstr's Avatar
Seat Belt Question
I have a 1995 xtracab that originally came with the 60/40 split bench seat. I recently scored some bucket seats out an 89-95 truck. I have been searching for the past few days but have come up dry. My question is for anyone who has done this swap, how did you handle the female end of the seat belt? On the passenger side its mounted to the tunnel and on the drivers side it was originally mounted to the floor. I am thinking of just making the mount point on the drivers side the same as it is on the passenger side. Any thoughts or pics would be appreciated.
Old Feb 20, 2019 | 10:47 AM
Stephen89's Avatar
I'm just going through the same thing. There seems to be 3 options, 1) check the salvage yards, by the time I called the place my seats came from, they had crushed the truck ! 2) Ebay, I just bought a good used set for $35, though they can get pricey: https://www.ebay.com/itm/Toyota-4Run...jTX:rk:31:pf:0
3) The current replacement belt assembly (Gray) seems to be Toyota P/N 73240-89155-B0 for around $50.
https://parts.lakelandtoyota.com/p/_...4089155B0.html
You should be able to used a passenger set if you can't find the driver's side, it just won't have the seatbelt warning switch ( I was going to cut off the unused center belt).
PS I did have to add a threaded mounting point to the tunnel.
Old Feb 21, 2019 | 03:28 PM
mrgtstr's Avatar
Thanks for the info! That's kind of what I had concluded since my post. Going to see if I snag one from a junk yard. If not, may go OEM or see about these companies I found online.
https://www.seatbeltsplus.com/
Old Feb 22, 2019 | 04:25 AM
Stephen89's Avatar
Yeah, aftermarket belts may be a good way to go. The Toyota replacement belts seem to include the buckle for the center belt, even though it's not used.
Old Feb 23, 2019 | 05:41 AM
pdx's Avatar
pdx
I replaced my nasty old ones with a set by Corbeau. They work great.
PRNDL
May 18, 2009 07:46 AM
Killer
Jun 13, 2007 05:22 AM
WSUWESTON
Mar 23, 2007 09:36 PM
gomezza
Apr 11, 2005 02:48 PM
