Saving Gass Question?
Old Jan 2, 2007 | 08:18 AM
keithguts's Avatar
Is it true that putting 31" tires on my 95 4x4 runner makes it use mor gass. I was thinking of going to 33", but now I don't no what to do. If 31" uses more gass, what will 33" do.
Old Jan 2, 2007 | 08:22 AM
amgraham's Avatar
The bigger tire you go with the more gas it will use generally. What size do you have now? I think the SR5 second gens came with 31s stock.
Old Jan 2, 2007 | 08:24 AM
bob200587's Avatar
yes it takes more "gas" to turn 31s or 33s than stock. It also puts more strain on the transmission. Figure out what gears you have and change them to an appropriate ratio for the tires you want to run.
Old Jan 2, 2007 | 08:39 AM
keithguts's Avatar
I'm now running 31", as this is what was on it when I got it. I do hope the gears are OK.
Also how much more gass does it us when running 31"?
Old Jan 2, 2007 | 08:54 AM
95RunnerSR5's Avatar
your truck came with 31's stock so it depends on what smaller tire diameter you go to. Also you probablly have 4.88 gears stock which are good for 33's on your truck. there is a chart somewhere around here that says what gears you have based on your door sticker.
Old Jan 2, 2007 | 09:52 AM
olharleyman's Avatar
Well for you to compair I runn 32 x11.5 x15 with stock 410 gears and i get around 240 miles per tank on my 90 4 runner it came stock with 225s now I'm going to 35s with 529s hopfully get better gas mileage and power torque as well
Old Jan 2, 2007 | 10:07 AM
The Lovely Boyo's Avatar
My standard tyre is 31''. Recently put on some mud 33'' with suspension and body lift. Used them wheeling over the holiday.
I have stock 4.1 diffs (2.4 Turbo diesel). Fuel economy was about 25% worse, poorer acceleration and noisy.
The 31'' are back on till I get enough cash to sort the diffs out. The 33''s go back on when wheeling.
Couple of pics showing the tyres I use.
Attached Thumbnails Saving Gass Question?-15-12-06_0950.jpg   Saving Gass Question?-21-12-06_0850.jpg
RobotMoose
Sep 2, 2015 05:53 AM
lectric80
Aug 11, 2015 12:02 AM
Gravel Maker
RuffStuff
Aug 6, 2015 04:27 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
