Sas yota
Sas yota
Ok looking for a solid front for my 92 pickup ext cab 3.0v6 and had a few questions bout doing a sas
If I swap my rear springs to the front and get z71 springs for the rear and custom mounts what kind of ride height would I expect my truck is on 36s now not sure if I wanna down size but I defiantly don't wanna go any bigger and I was wondering what size shackles I would need as well as shocks I know most kits come with springs but I wanna do something custom and about drive shafts could I use the stock front I know with my ifs pro comp lift it has a aluminum rear drive shaft spacer would that have to come off and where the drive shaft splits it is moved toward with a new bracket and wheel spacers do u have to run them with sas? And can I use the same brake calipers that I have now on the truck or do I have to get the ones off the solid axle truck? All info will help so thanks I plan on ballin it on a budget lmao
primordialbeast117
Dec 19, 2015 12:23 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
Toys4parts
Sep 26, 2015 01:56 PM
