SAS Planning Help
Old Sep 20, 2015 | 09:13 PM
stanz's Avatar
SAS Planning Help
So I picked up a 1980 solid front axle for my 86 4runner. The housing is a little bent but I got a good deal and it's hub to hub complete.
My buddy is a fabricator and our plans are as follows:
-Add 98 Tacoma rear axle to widen stance 2 inches
-Fab new housing for front axle to match the width of the Taco rear
-ARB air lockers front and rear
-Go with T100 master cylinder, calipers and wheel cylinders (already running T100 dual diaphragm booster)
-Upgrade to vented discs from ??? model/year
-Coil spring/track bar the front using coils, towers, etc. from a 66-77 Ford Bronco
-Maintain 2 inch lift height
-Maintain stock 15 in wheels
After the knuckles, I know very little about what changes over from year to year and what 1980's axle parts will work to make this work. My questions...
-Will the 1980's caliper mounts accommodate the T100 calipers?
-What spindles should I use? What rotors, what wheel bearings/hubs?
-What alignment specs should I be using?
Anything else I should know?
Thanks in advance!
Old Sep 20, 2015 | 11:55 PM
wyoming9's Avatar
Red face
If your friend is a good fabricator !!!
You should have nothing to worry about
Old Sep 21, 2015 | 12:04 AM
stanz's Avatar
He's the best in the business as far as I'm concerned. He's not a Yota guy however. I just need to know what mix of models/years to source the brake and wheel bearing parts from.
I know he'll kill it on the rest.
Old Sep 21, 2015 | 11:47 AM
wyoming9's Avatar
Red face
Having only ever work on one T100 all I can say is everything is different
Do you all ready have the T100 Finding parts for them can be a pain .
Why not the Tacoma Brake parts ?? Lots more of them around.
Your most likely going to need to fabricate hard points to mount the calipers no matter what you use.
The Tundra ones are to big without grinding the calipers.
Have you read the threads pertaining to your SAS
Old Sep 21, 2015 | 11:59 AM
stanz's Avatar
T100s run 15 in wheels and I'm going to be using all new off the shelf parts, not boneyard. The more bolt-on the better.
Any idea if Toyota spindle sizes and wheel bearings are interchangeable throughout the years?
Old Sep 24, 2015 | 06:45 PM
stanz's Avatar
Anyone else out there that can comment on interchange on spindles, hubs, wheel bearings, rotors?
Old Sep 25, 2015 | 03:45 AM
muddpigg's Avatar
If you change spindle you have to mount front brakes differently. I used the common IFS calipers and LC rotors.
I used some trailgear plates for spring mounts but am 99% sure they are bending. Will know for sure when I pull them to swap in another set. So moral of the story research your parts. Fund were getting tight since I pieced my kit together and decided the save on some basic parts. Now I'm spending money twice for same part.
Old Sep 25, 2015 | 01:09 PM
stanz's Avatar
Help me fill in the blanks here... what other spindles would even fit? No Trail Gear parts are going on my ride. I have their rear tube bumper and it didn't survive a 3mph bump into a pole.
Old Sep 25, 2015 | 02:41 PM
muddpigg's Avatar
IFS spindles and calipers.
Old Sep 25, 2015 | 03:05 PM
stanz's Avatar
So IFS spindles fit 79-85 knuckles?
Old Sep 26, 2015 | 12:20 AM
dropzone's Avatar
Fossilized
79-80 have issues getting the FJ vented rotors to clear
Old Sep 26, 2015 | 04:05 AM
muddpigg's Avatar
I've seen it done but haven't researched it. IFS changed spindles to match wider rear. Will allow you to not run wheel spacers.
Old Oct 9, 2015 | 09:53 PM
stanz's Avatar
Still feeling really in the dark here... how do I go about learning more about the interchange and combo options... "use this rotor with this hub and this caliper... etc."?
My goals:
-Use vented rotors
-Use latest model calipers possible that fit under 15 in wheels
-No wheel spacers for clearance
Hoping this helps clarify my ask.
Old Oct 30, 2015 | 10:33 AM
84 yota dude's Avatar
Another thing you can do is run tacoma brakes...
http://www.expeditionportal.com/foru...en-Motorsports
RickyD
Oct 2, 2015 07:53 AM
Obmi
Sep 16, 2015 02:13 PM
Flying91
Sep 10, 2015 03:41 PM
an1mal_69
Sep 8, 2015 09:40 AM
seab1209
Sep 3, 2015 05:41 PM
