SAS Dual-Case Front Driveshaft Problem (?)
Old Dec 11, 2010 | 09:31 AM
  #41
humboldtMUD's Avatar
heres my angle at the pinion, worse at the tcase
i know shims are a no no, but it would make a good troubleshooting tool. i think 4crawler sells or used to sell them
Old Dec 11, 2010 | 10:51 AM
  #42
ScottyC's Avatar
Tatton uses standard 1310 u-joints in his shafts as i have ordered one of his off of Ebay before. 1310 u-joints do not have enough clearance to work on a Toyota. U need Toyota joints/flanges which are good to 41 degrees. It won't stop the vibes itself, but it will stop you going through u-joints. Or, you could try the Tom Woods offset u-joints for more clearance.
Old Dec 11, 2010 | 02:48 PM
  #43
muddpigg's Avatar
Angle is not the worst I've seen, but if Scotty C is right about Dana 1310 u-joint you don't want them, stock yotas are stronger and as Scotty C mentioned more clearance.
Call Jesse High Angle Drivelines awesome work and he is very versed drineshafts. Shoot Marlin references him on the Marlin website.
Old Dec 11, 2010 | 03:34 PM
  #44
yup 1310/toyota goofy ujoint that can only be bought at rockford drive shafts. i fliped the driveline around and its maxed just sitting there. tom woods uses toyota ujoints in there shafts? jesse is assosiated w/ marlin or no? id just like the noise to go away, 2nd gear and faster, very annoying.
Old Dec 11, 2010 | 03:42 PM
  #45
muddpigg's Avatar
http://www.marlincrawler.com/axle/dr...ront-driveline I guess thats the case. Highangle used to just be recommended for complete drive shafts. Call Jesse he's very knowledgable been doing this for a living for awhile. He never talked down to me nor acted like I was wasting his time asking tons of questions. He made two shafts for me and I bought another used. The last time I needed a shaft lengthen I just went local but that was to lengthen and no balance so no big deal.
Old Dec 11, 2010 | 03:46 PM
  #46
nice thanks ill give him a call monday
Old Dec 11, 2010 | 03:50 PM
  #47
muddpigg's Avatar
post back if you find anything out.
Old Dec 12, 2010 | 02:22 PM
  #48
ScottyC's Avatar
Not a goofy joint at all. That should just be a standard 1310 joint you could buy anywhere. The flange that bolts to the pinion is a custom flange.
As said, Toyota joints are night and day stronger than a 1310.
Old Dec 13, 2010 | 07:44 AM
  #49
no man, stock toyota flange at pinion and case, 1310 on the shaft. its a conversion joint, and not my idea. rockford k721 joint
im going to call marlin in a bit here, but im wondering how much this conversion joint comes into play with...
Old Dec 13, 2010 | 01:22 PM
  #50
well jesse said my angles are all f'd up (qoute), and the right way to fix it is to duel case and lengthen the shaft. high pinion would help, but duels the way to go. so as far as whitewhale goes, you have duel already right? a guy at marlin suggested getting the high pinion and their cv shaft, which uses toyota joints. i guess high pinion is the call, and ill see if i need a new shaft.
lledwod
Aug 30, 2016 01:03 PM
shisha1999
Mar 16, 2016 12:25 PM
crashburnoveride
Aug 28, 2015 09:20 PM
karbin
Jul 5, 2015 11:37 PM
