Safari Snorkel Install 1st Gen 4Runner
Old Dec 18, 2009 | 09:59 AM
TerraXpeditions's Avatar
Originally Posted by rangerruck
very nice job; after my small lift and a borla pipe and such, I may have to tackle this one myself. What did you use to reseal/waterproof around the holes you drilled and cut? how snug is it around the big hole you cut? could it have been tighter? any changes you would have made during the process, now that you have it in?
The drilled holes, i painted to prevent rust. The only hole that needs to be sealed is the threaded piece connecting to the air box.... maybe a piece of neoprene or closed cell foam or silicone "rescue tape" would be work.
Big hole worked out fine, but like I said, I had to grind it down a bit. Like I said, I'm not very imaginative so I dont know what would be done differently.
Old Feb 13, 2010 | 11:45 PM
just call me smithy's Avatar
made my snorkel head in about 20 minuts and it was about $15.00 for all the parts......... i made it to mimic the new safari ssnorkel heads.......i liked how it terned out ....what do you all think?
Attached Thumbnails Safari Snorkel Install 1st Gen 4Runner-complete-snorkel-2.jpg   Safari Snorkel Install 1st Gen 4Runner-snoorkel-parts-2.jpg
Old Feb 13, 2010 | 11:46 PM
one more pic!
Attached Thumbnails Safari Snorkel Install 1st Gen 4Runner-snorkle-riser-2.jpg
Old Feb 14, 2010 | 09:09 PM
junkers88 nice crome lbow where did you get that at? Autozone?
Old Feb 15, 2010 | 07:01 AM
  #25
Junkers88's Avatar
Napa. Same place that I got the filter, hose and connections.
Old Feb 15, 2010 | 04:30 PM
  #26
iamsuperbleeder's Avatar
Advance Auto Parts now sells the Spectre adapters too; I just seen them today
Old Feb 15, 2010 | 05:08 PM
  #27
sweet..that shure is shinny
Old Sep 2, 2010 | 09:09 AM
  #28
Phessor's Avatar
Very interesting
Phessor
Old Sep 2, 2010 | 09:17 AM
  #29
Magnusian's Avatar
From: Downtown Heckronto, Ontario, Soviet Canuckistan
This thread just reminded me that I need to get some 4x4 front fenders so I can put my safari snorkel on.
Nice writeup! I knew you EFI guys had to do some extra work to install them, but didn't realize it was so involved.
I don't get why there isn't a LHD version of this snorkel though, must be too hard to come in through the passenger side. Kinda weird having the antenna divot in it on a vehicle that has the antenna on the other side, but one can't have everything. Does the snorkel block much of your view on the left?
One mod to the snorkel you might want to try is a piece of metal screening in between the air ram and the snorkel if you aren't doing a prefilter, it'll keep a lot of the bigger stuff that passes through the air ram grill (such as small bits of gravel) in a place that is easy to get at to clean and if it's not a super tight mesh it shouldn't have a noticeable affect on airflow.
Old Sep 2, 2010 | 09:55 AM
  #30
thralldad's Avatar
Good job! What part of TX are you in??
Old Sep 2, 2010 | 11:33 AM
  #31
morena67's Avatar
I like it too...
-Can you please make a "mini thread" of how it's made?
I'm Kind of confused about the air intake...!
Old Sep 2, 2010 | 11:43 AM
  #32
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Here's a GREAT intercooler for Turbo guys...
Old Sep 2, 2010 | 11:59 AM
  #33
Originally Posted by Junkers88
I've been trying to figure out a snorkle set up for my Supra VMAF/battery swap for a couple of years now and just can't seem to find one that works. If I'd have been smarter I'd have gone with the factory set up and used a Safari like you did.
Guess I'm stuck with cutting the hood and mounting that pig under a scoop.
The mount is easy enough to make it just looks freaking strange. *grin*
Not sure how the flapper valve is gonna like sitting on top that motor rocking back and fourth
But I like that idea, and have often thought about if I had EFI what I would do..
Just pick up your MAF box and place it straight on the P-side fender, with the hose attached just like it is...
Then, you can run a flexy duct to the P-side firewall, and have inside air
I'm dreaming up a way to do it that uses something like this part...
So it's high and tight out of the way of passenger feet
Old Sep 2, 2010 | 12:01 PM
  #34
yotamonsta-'s Avatar
Texas boys in the house!!! Nice work man a beautiful runner!!!
Old Nov 8, 2010 | 12:19 PM
  #35
Bye Bye Yotatech
Old Nov 8, 2010 | 02:01 PM
  #36
yotarover's Avatar
nice build i might just use your idea
Old Nov 8, 2010 | 02:12 PM
  #37
morena67's Avatar
-Lucky guy...!!!
Old Nov 8, 2010 | 03:11 PM
  #38
Originally Posted by morena67
-Lucky guy...!!!
Lucky?
Old Nov 8, 2010 | 04:57 PM
  #39
morena67's Avatar
...Ha...!
Old May 7, 2011 | 06:31 AM
  #40
....Don't forget to plug the hole in the bottom of the airbox....
