S2S Tuning 3VZ-E Cam Disscussion
Old 10-13-2006, 11:55 PM
  #121
Weasy2k's Avatar
the shims provided dont just bring it right to proper clearences...i would DEFINATLY check the clearences 100% for sure!
Old 10-14-2006, 02:58 AM
  #122
Bumpin' Yota's Avatar
Any tech that tells you that they've never seen one out of spec has never bothered to actually check...and Weasy is right, put the shims under you origional OEM shims then check clearances.
going off of what i remember i think the intake had .007"-0.009" of clearance and on the exhaust side had 0.009"-0.011" of clearance, but double chech the Toyota FSM for exact values.
Old 10-14-2006, 09:11 AM
  #123
Weasy2k's Avatar
you most likloy have to replace 70% of them...
These are cam grinds so the cams are smaller then stock by about .020-.030" and you got .015" shims so you have to makeup for that extra clearence
Old 12-16-2006, 07:07 PM
  #124
Morphine's Avatar
BUMP and REVIVAL
I'm looking into this and hope you are still producing the regrinds. Bumpin passed some info my way about some cams for me to get hold of so I should have no down time. So whats he best way to get in touch with you? PM? Email? Forums?
-=Morphine=-
Old 12-16-2006, 08:34 PM
  #125
pm him here is what i did....
Old 12-17-2006, 06:09 PM
  #126
Morphine's Avatar
I won the auction for the cams, PM'd Weasy2k and emailed him as well...This will be a great slightly after xmas gift for myself!!!!!
Old 12-18-2006, 04:09 PM
  #127
Weasy2k's Avatar
Ok guys a little update...
Im backlogged with these units Yes the next one wont be going out till after the new year as the cam grinder is going to do my last order for the year (3 5vz-fe cams ) and then closing down till Jan 4th. Just in the last 3 weeks the demand for these bad boys has gone pritty crazy People are seeing how damn worth it they are. EVEN toyota dealers!
feel free to continue firing me emails or pms and all answer them as fast as i can!
Old 12-19-2006, 10:13 AM
  #128
aviator's Avatar
Ok just did a little review of some of the old posts and a question popped up... The new cam changes the duration of the valve cycle right? Why are we concerned with restoring the original valve clearance? is it a matter "interference"? would not a wider opening cam be better? or with the grind is the cam actually open less wide?
second I'm a little fuzzy on the need to remove the ECU when running a stage 1 "stand alone" set up. Does not the engine need the ECU to control the injectors and so forth? How would removing the ECU allow you to go to a sequential injection?
help weasy!
Old 12-19-2006, 10:18 AM
  #129
suprathepeg's Avatar
REPLACE OR TUNE THE ECU is what he means.
Old 12-19-2006, 10:25 AM
  #130
Not so!! (Damn you scared the bejesus out of me supra!! lol)
I have the stage 1 cams which btw ARE oem ECU compatible!
Originally Posted by Weasy2k
There will be Stage 1 to 4 for this engine 3 has been made 4 is in the air and 2 is in my cam grinders head
1 - what ill call "TOYOTA SHOULDA HAD THIS STOCK" TSHTS Cam
2 - a bit more pull higher up with some loss down low
3 - focusing 3000-6000rpm power range off-roaders beware
4 - Complete race cam 4500-6500rpm
Stage 1 and 2 work well with stock ecu #3 has caused problems so unless you can live with that you have to fix the problem by going either SMT7 and removing maf or plug and play ecu
Stage 4 wont work on stock ecu for sure!
Thanks guys for your interest keep askin away if you have any more!
ladybugRC
458
08-21-2020 10:41 AM
LittleUgly
15
01-02-2020 01:30 PM
moparbay
10-06-2015 09:24 AM
the_supernerd
10-01-2015 09:20 PM
tylermx71
09-29-2015 08:49 PM
Quick Reply: S2S Tuning 3VZ-E Cam Disscussion
