Rusted shock mount
Old Aug 1, 2013 | 06:22 PM
94 SR5 Mountaineer's Avatar
Rusted shock mount
I'm in the middle of a bed off restoration and ran into a problem. One of the shock mounts is badly rusted and I'm afraid when I put the new shocks on they won't move as freely as they should. I don't want to go through the trouble of cutting off the whole bracket, either. Thought about looking for something like the mount itself to weld back on. From what I can tell it's either a 7/16" or 11 mm bolt that goes through the 3/4" or 19 mm sleeve. I'd appreciate anyone would could suggest a fix or confirm the hardware size.
Thanks
Old Aug 1, 2013 | 07:03 PM
arlindsay1992's Avatar
If there is no fear of it breaking off, I would just clean it up with a wire wheel on a drill, grease it up, and put it back together. There is hardly any rotation on that stud as the suspension cycles.
Old Aug 1, 2013 | 11:00 PM
wyoming9's Avatar
Red face
I think you have your work cut out.
What does the rest of the under carriage look like .
Looks like time for some sand blasting
I think some new bolts for the shocks will help much.
young buck
18
Aug 27, 2018 02:40 PM
Luvmeye22re
Aug 4, 2015 03:53 PM
terminator
Jul 27, 2015 07:13 PM
SMOD
Jul 27, 2015 01:45 PM
MTLroadierunner
Jul 20, 2015 03:07 PM
