running rough idle
running rough idle
so i rebuilt 22 re from the head up as well as new timing chain set and cover to cover all my basis. so chain timing is set properly and i set ignition timing to 12 degrees BDC which is what the hanes repair manual recomends for this motor and the motor is running rough at idle. i dont have tags on it so i havent put any road testing on it it will idle but its a rough idle. was wondering what every one else set there timing to or is it just since i rebuilt the motor and havent "broke in" the motor.
What year is the truck? Did you short terminals T and E1 before adjusting the timing? Since you only did the timing chain and head gasket, you won't have to break anything in.
Download the FSM for your truck in my sig. It explains it better than the Haynes manual.
its an 88 toyota pick up sorry for not posting that on there earlyer. and im not shure o what your talking about for shorting the terminals but currently trying to downlad the fsm thank you for the link
Sep 4, 2015 09:27 AM
Jnkml
Jul 6, 2015 01:20 PM
