RTV on intake manifold gaskets? (Knock sensor replacement related question)
Old Jun 11, 2020 | 08:53 AM
gregory_wilcox's Avatar
Originally Posted by scope103
"There's yer problem, lady!"
Remember that you have to get three sprockets in sync, so you will (probably) need to adjust both cams. As you point out, the 3VZE is a non-interference engine so you can turn the cams once you've loosened the timing belt. (In an interference engine, you can feel the pistons pushing on valves, so you just let up and figure out what you did wrong. The problem is cranking it over with the powerful starter motor.) Because of the way the timing belt is retained on the crank sprocket, it's not easy to move the timing belt on that sprocket even when loose (which is exactly what you want). Again, it doesn't matter where the belt is on the sprockets, just that all three line up.
To remove the lower timing cover, you'll have to remove the crankshaft bolt (you know that). Absolutely doable, but a challenge. The spec tightening torque is 181 lb-ft, and you have to make a tool to keep the crankshaft from turning. But if you haven't retrieved that bolt yet, you're probably stuck with removing the lower cover. In which case, yeah, just replace the belt.
Others may disagree, but I think successfully replacing the timing belt is the task that separates the competent amateurs from the hacks. Are you up for it?
Originally Posted by ZARTT
Hi:
I rebuilt my V6 engine about 9-10 yrs ago.
I was careless when reassembling it, and this picture is the result.
I have no idea how long this situation existed, but as long as I can remember, the engine always made a weird sound from 2000 RPM onward.
Look at this and be careful.
Art
Damn! Thanks for the cautionary tale.
Old Jun 11, 2020 | 09:19 AM
scope103's Avatar
Originally Posted by gregory_wilcox
... I've seen that you can use the trick with the starter to break the bolt with a breaker bar...
Yeah, yeah. Everybody loves the starter trick. It might even work, if it doesn't kill you in the process.
But how are you going to get the bolt back in? You still have to hold the crank against the 181 lb-ft of torque. So avoid the fireworks and just build your tool first. Here's my preferred tool: https://www.yotatech.com/forums/f116...h-3vze-137934/ The comments in that post list a number of other very good shop-built tools. There are even some no-tool methods (I'm fascinated by the idea of stuffing nylon rope into a cylinder).
Old Jun 11, 2020 | 11:15 AM
I have a manual, so it sounds like I might be able to just put it in 5th gear and put on the e-brake
tomboarderns
Jan 31, 2010 07:14 AM
Epikos
Apr 1, 2009 02:26 PM
okidoc
7
Jan 12, 2006 06:02 PM
Bumpin' Yota
9
Sep 23, 2004 06:05 PM
DH6twinotter
14
Dec 23, 2002 06:58 PM
