rough starting 22re
rough starting 22re
first off, i'm new to the forum and i've been searching for the problem my truck is having but can't seem to find an exact match.
every once in a while( very 2 or 3 weeks) my truck won't turnover. it just clicks once under the passenger side dash and thats it. all my gauges show full power and battery checks fine. and i've tried hitting the starter while someone cranks it and that works usually. but when it does finally start it runs really rough and blows blue smoke for a few seconds then levels off fine and runs normally. anyone have any ideas? is the starter getting stuck out after it starts?
any help is appreciated. i'm a newbie so please excuse.
I would check all the usual suspects for starting issues. Batt/ batt voltage , starter, all other ign components. As far as running rough and burning oil , check afm,, tps, aav, etc. oil burning on startup could be valve guide seals, could be rings if burning all the time. Have you done a compression test ?
it kind of sounds like a loose battery connection and maybe the running rough and blue smoke are something completely different. Blue smoke is almost surely valve seals, nothing to worry about but check the oil pretty often till you replace them.
personally, I think its a couple different issues inside the starter, like worn contacts, and the starter gear not disengaging from the flywheel causing the engine to bog.
From my searching, its not a common issue with these trucks, but its on the top of my priority list to get fixed as I would rather not get stranded somewhere.........not to mention its eating me alive!!
