Rough idle, white smoke, clean oil, losing water, and gas like smell from radiator???
Old Mar 3, 2007 | 06:54 PM
kmchby76's Avatar
Ok, I have a mystery here. My brother in law's 95 3.slow is acting wierd. As of now, no cel. Start the runner and it has a very rough idle and dies. Some white smoke from the tail pipe, not heavy just light. Loses water, and a gas like smell from the radiator. The oils is clean, no sign of water. Is it possible for water and gas to mix in the intake manifold or anywhere else. Have not been able to do a compression test yet, but will try this week. Is it still possible to have a blown head gasket and not have water and oil mixing on the dip stick?
Old Mar 3, 2007 | 08:46 PM
TNRabbit's Avatar
Can you say BLOWN HEAD GASKET?!? Head gasket doesn't necessarily mean oil/coolant mix; depends on where it blows. But it definitely sounds blown. Compression test first. Coolant system leakdown test second while plugs are still out from compression test, then if coolant is indeed leaking out somewhere, turn over engine & look for the cylinder blowing water out. You can get a nice coolant tester & compression tester for about $110 total from Sears.
Old Mar 3, 2007 | 08:49 PM
curtiswyant's Avatar
You've got problems...pull the heads, probably time for a complete top-end overhaul.
Old Mar 3, 2007 | 10:31 PM
notanymore's Avatar
that sounds like a hg to me, and with the 3.0 its not too unusual
Old Mar 3, 2007 | 10:57 PM
DudeBud's Avatar
typical 3.blow. not all do it, but most do.. good luck
Old Mar 4, 2007 | 09:30 AM
kmchby76's Avatar
Thanks all, I always assumed a bhg meant oil and water mix. Does anyone have or seen a write up on replacing the hg on a 3.slow?
Old Mar 4, 2007 | 10:34 AM
TNRabbit's Avatar
OMG! There are at least a hundred threads on this; get a new one every month! Go to advance search, type in blown head gasket and search away! The FSM link at the top of this forum is ESPECIALLY helpful...
good luck.
Old Mar 4, 2007 | 10:54 AM
kmchby76's Avatar
good luck.
Thanks for the suggestion, but I must be missing something because I can't find the FSM link.
Old Mar 5, 2007 | 06:59 AM
TNRabbit's Avatar
My bad; we have it posted on www.toyotanation.com
http://personal.utulsa.edu/~nathan-b...fsm/index.html
Old Mar 5, 2007 | 07:02 AM
kmchby76's Avatar
Thanks TNRabbit!!
Old Mar 5, 2007 | 07:28 AM
rdlsz24's Avatar
Not neccessarily. On my 22RE I had a blown headgasket but it was leaking down the side of the block near the #4 cylinder. I didn't have mixing going on, but was loosing coolant at an alarming rate. I finally figured out what was causing it when I heard a hissing noise when I stopped driving one day and traced the noise to where the head meets the block and could see bubbles.
Rob
bigjstang
Jun 2, 2025 03:56 PM
Avenged
Jul 9, 2015 07:55 AM
Cplmike
Jul 8, 2015 08:47 PM
Jnkml
Jul 6, 2015 01:20 PM
