roaring sound after rotor swap?
Old Apr 27, 2013 | 06:33 PM
Rusted Rooster's Avatar
Hi guys, I replaced rotor on 1986 4x4, was more parts in that lock out hub then I thought! well It seemed like I got all back together ok.. Took her for a test drive, and started to get a roaring viberation sound? any ideas? hate to tear it back down,,maybe got wheel bearing too tight? Thanks.
Old Apr 27, 2013 | 06:38 PM
Forgot to say......only after 45 mph and can bearly hear it when I lock out hub in 4x4?
Old Apr 27, 2013 | 08:19 PM
rbuchmann's Avatar
Can you tell what side its coming from? Did you repack the bearings? Did you maybe tighten the axle nut too tight? It sounds like you have a bearing issue.
Old Apr 28, 2013 | 04:53 AM
Thanks rbuchmann, yes it is right side, I just snuged tight the axle bolt with channel locks, then there was that funny looking lock washer that goes on next, then another axle bolt that according to repair book, I torqed that one tight.
Old Apr 28, 2013 | 04:56 AM
guess its time to tear down and retry,, may wait for a few more life lines for you guys.. thanks again,
Old Apr 28, 2013 | 07:47 AM
Just drove to Dads house with hubs locked in and in 4x4 high, no noise at any speeds, but when hubs turned to "free unlocked" I get the noise at highway speeds?
Old Apr 29, 2013 | 08:16 AM
Are you out there , WASKILLYWABBIT? You always fix me up in the past
Old Apr 30, 2013 | 01:04 PM
Ok. Tool lock out cover off 10mm bolts. The gear is not coming out with cover and spring? It does on other side Could that problem? Thanks for any advice.
Old Apr 30, 2013 | 01:58 PM
wyoming9's Avatar
Red face
Yes that would be a good bet.
Your driving with one hub that stays locked while the other one is free to keep it simple
Old May 1, 2013 | 09:10 AM
Thanks wyoming
88sasturbotoy
Jan 30, 2026 01:57 PM
sandyota
Feb 4, 2021 11:16 AM
rondogracing
Jul 14, 2015 07:00 PM
mlavery85
Jul 12, 2015 10:33 AM
msane99
Jul 11, 2015 08:08 PM
