Rig Bucked very hard doing 70mph
Old Feb 19, 2007 | 05:15 PM
keithguts's Avatar
I was crusing along this morning doing around 70, all of a sudden, the rig bucked very hard and then it was fine.
I was told maby it was the trans shifting into high. At the time, I was doing around 70 mph, and I would think by then it would be in high. I was also told that maby the trans was cold, but I was already driving for 35 min's, and would think it be warmed up by then.
I will sey this tho, it was very windy and very cold around 15-18. Wind chill around O. I was maby thinking it was a little gass line freeze.
Any help on this would be great.
Old Feb 19, 2007 | 05:30 PM
pruney81's Avatar
Dude, you post alot of random questions about your car. Maybe you're a little paranoid, relax, if it drives fine don't worry about it.
Old Feb 19, 2007 | 05:33 PM
CLEANSR5's Avatar
Yea, maybe perhaps you weren't in high and you unintentionally stepped on the skinny pedal it and shifted. Sounds normal if that's the case, since it operated fine afterwards, you shouldn't have too much to worry about, that's my guess.
Old Feb 19, 2007 | 05:39 PM
rezrunner92's Avatar
Maybe it got cooled off enough for a second for it to cancel overdrive. Kind of like it does in the mornings before it warms up. Then again maybe you should drive by there in another car and look for a body.
Old Feb 19, 2007 | 06:14 PM
UKMyers's Avatar
Dude put the crack pipe down for a minute and reread what you typed it makes no sense to me... I didn't know transmissions had "high" and "gass line freeze" ???? WTF? Your gonna have to give a little better description for people to help besides a buck going down the freeway.
Old Feb 19, 2007 | 06:25 PM
91_4x4runner's Avatar
I think by high he means from 5th (OD) to 3rd or 4th,. Was it on a grade or flat road?
Old Feb 19, 2007 | 06:27 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
i wasn't aware toyota autos had a 5th gear
it probably wasn't anything to be concerned about if its still driving fine. if you suddenly had no acceleration, i'd say look out the rear view mirror for your tranny
slosurfer's Avatar
Maybe you just hit a dickfer?
Old Feb 19, 2007 | 06:31 PM
sts2usnss's Avatar
BWAHAHAHAHAHA!!!! A "dickfer". Haven't heard that one in a while!
Old Feb 19, 2007 | 06:32 PM
Hilarious, Mr. Akroyd.
Old Feb 19, 2007 | 07:18 PM
blakjak's Avatar
What's a dickfer?
Old Feb 19, 2007 | 07:23 PM
toyota_mdt_tech's Avatar
I suspect it went into "fuel cut" caused by a dirt speed sensor in the speedo head. If it sees a double pulse instead of the normal one, it instantlyu thinks its going twice as fast (in your case, 140 mph) and it shuts off the injectors. CHeck codes to see if you have a code #42, speed sensor code.
Kyle95sr5's Avatar
Am I supposed to be able to go 70 in my 4runner?
Old Feb 19, 2007 | 07:39 PM
YotaFun's Avatar
I know this is pertaining to the 2nd gen, but my third gen did a similar thing, and had a nice loud bang to it, I thought I either blew out my rear, of something went god awful in the Tranny, but after the little kick, wouldn't you know the tranny felt tighter and more responsive then other, I even could start pulling off the dukes of hazard power drifts.... (however since then it has lost that nice little kick and was back tot he way it was before the buck)
If it is driving fine still I am sure your fine.
What toyota_mdt_tech said sound like it might have been it
Old Feb 19, 2007 | 08:25 PM
trythis's Avatar
It could be the tranny shift lever wasnt all the way into D. Sometimes my shifter will show the orange in the D indicator but still be in 3. It may have been sticking in 3rd and appeared to not be warmed up, then slapped from 3rd into OD when the shifter popped all the way into D
Old Feb 19, 2007 | 08:27 PM
chadbobb's Avatar
Calm down man.....
internet flaming isn't the answer. Drama online is ridiculous.
It was pretty obvious to me what he was talking about, and it seems that way to most people who gave an answer that was at least related to the question.
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
Backcountry411
Jul 24, 2015 08:06 AM
TURBOrunnerNM
Jul 20, 2015 08:31 AM
skoti89
Jul 8, 2015 12:05 AM
