Reverse won't stay engaged
Old Feb 14, 2014 | 02:08 PM
Romans117's Avatar
Transmission rebuilt by T&M Transmission Exchange two years ago. Will shift into all gears and will run just fine forward and in 4 wheel drive. Pops out of reverse after a foot or two travel. Can't be held in or grinds real badddd.
Whats the deal?
Old Feb 14, 2014 | 03:38 PM
big bear's Avatar
5 speed stick ?
Old Feb 14, 2014 | 04:27 PM
Romans117's Avatar
Yes, 5 speed manual.
Old Feb 16, 2014 | 06:21 AM
Chaser Johndoe's Avatar
Your shifter bushings are probably bad. Order a set from Marlin Crawler. I did, love them. My problem was a high pitched squeel in fifth at highway speed. Rubber bushing was completely gone. Order the lower and upper bushing cheap insurance I think it was less than 30 for both including shipping.
Old Feb 16, 2014 | 09:58 AM
Romans117's Avatar
Where in the transmission are these bushings?
Old Feb 16, 2014 | 10:15 AM
under the shifter plate. remove the boot and 6 screws.
Old Feb 16, 2014 | 10:21 AM
Romans117's Avatar
Thank you for your posts. Please advise how the shifter bushings prevent the transmission from staying engaged in reverse.
Old Feb 16, 2014 | 10:36 AM
if your bushings are worn too much it won't engage the gear properly.
Old Mar 2, 2014 | 07:49 PM
Blueman's Avatar
Did those bushings fix the problem? In the world of VW bugs that same failure (not staying in reverse) indicated a bent shift fork.
Old Mar 3, 2014 | 04:24 AM
Romans117's Avatar
I contacted t&m and they advised it was a tooth or two that is broke off the reverse gear. Do to the fact I can run the truck forward with no issue staying engaged, I agree it is a tooth issue. How ever I am not sure how that is possible as I have treated the truck very well and don't put it into situations to break anything. I was stuck a lot in the snow the last two weeks of February running my trapline. I run in 2wd til stuck then lock them in 4wd. Technically not stuck in my book, but..... the trans is w56. Suppose to be tougher than the rest. So it looks like the trans has to come out. Just wish I have the knowledge base to tear it down. Sounds like the reverse gear only needs replaced. Anybody with pictures please help.
JAmdor3
Aug 11, 2015 10:53 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
rchavis
Jul 27, 2015 07:41 AM
jgwerth
Jul 16, 2015 03:23 PM
Poncho0206
Jul 10, 2015 06:21 PM
