Replacing Shocks
Old Jul 27, 2007 | 04:35 PM
tktmsa's Avatar
Replacing Shocks
After bouncing down the road for the last couple weeks, time to put newshocks on. What size sockets do I need 23mm? 24mm? I only have up to 22mm, close but no cigar. Thanks!
tk
1994 4runner 3.0 5sp
Old Jul 27, 2007 | 04:42 PM
TC4RNR's Avatar
i use a tire iron from my Dodge Ram1500.
sorry for the BS, i'll check it out for you later
Old Jul 27, 2007 | 06:24 PM
tktmsa's Avatar
don't think I haven't thought of that.
Old Jul 27, 2007 | 06:45 PM
dijlop's Avatar
i always try my tire irons. lol. course they never work... maybe i should get a dodge. or spend the 2 bucks to get a new socket. yea.
Old Jul 28, 2007 | 02:35 PM
MMA_Alex's Avatar
for the front shocks the bottom bolts are somewhere around 7/8" (that socket seems to fit well, and yes i realize its actually metric). the tops are.... 14mm? if i remember correctly. I'm working on getting the bottoms loose still, and keeping the shock from spinning while removing the top nut. I've already hit em with pb blaster atleast 20 times in the last 6 months lol, and still no luck so I think i'll be getting the torch out for the next attempt
Old Jul 28, 2007 | 03:06 PM
frodin1's Avatar
Wrap a pipe wrench around em' It'll come loose!
Old Jul 28, 2007 | 07:21 PM
Jay351's Avatar
Dont even bother trying to unbolt the front ones, we just cut mine out.
Old Jul 28, 2007 | 08:20 PM
thook's Avatar
I'm guessing you're referring the front shocks? The rear ones on mine are 17mm. The front is a 22mm on one side and a 24mm on the other at the base and the top is 14mm. Yours is probably a 24mm. Crescent wrenches (or channel locks) on either side have worked for me...if you can get one inside the control arm and lock it down against the arm while you turn the other.
Old Jul 29, 2007 | 09:46 AM
dijlop's Avatar
sounds almost as difficult as my torsion bars. ive tried everything. oh well. some things you just have to live with i guess. at least until u get ahold of something that shoots fire or something. then u show it whos boss. hehehe
Old Jul 29, 2007 | 09:49 AM
Paul H.'s Avatar
One thing to do before attempting the top nuts is to remove all of the crud out of the threads. Use a wire brush, you won't believe how much this actually helps.
Old Jul 29, 2007 | 11:26 AM
thook's Avatar
Probably moot now, but a pair of channel locks on the the bushing flange will hold it still.
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
rushw
Jul 18, 2015 01:46 PM
1994toyota
Jul 17, 2015 03:03 AM
akaphilly
Jul 9, 2015 02:34 PM
