Replacing green coolant with Toyota red.
Old Oct 17, 2013 | 02:49 PM
  #41
Gamefreakgc's Avatar
Originally Posted by j2the-e
To add to what others have said about Toyota's 100k mile change interval:
It only applies to the pink (sllc- super long life coolant)
And after the first 100k they recommend every 30k. It's just a ploy to keep the calculated cost of ownership low and to a lesser extend, have less impact on the environment. Its all about cost of ownership these days. Lower cost of ownership = more car sales.
Think 100k mile iridium plugs, lifetime auto trans fluid, timing chain, and now 10,000 mile oil change intervals.
The red (llc- long life coolant) I believe was recommended every 30k. But don't quote me on that one. I've always changed my green coolant every 2-3 years.
Yes, you are correct. My wife's Corolla used the "pink" Super Long Life Coolant. The two are different. Maybe the thought that the Red goes 100k is the source of all this controversy!
The Toyota Red is just like the green, same service intervals.
Old Oct 17, 2013 | 03:14 PM
  #42
GrandPrix's Avatar
Has anybody used the expensive but brilliant waterless coolant? Thinking of doing the head gasket and then going to waterless. Thanks.
Old Oct 17, 2013 | 03:43 PM
  #43
Teuf's Avatar
375 boil point? MMMMMMMMMMMMMMMMMMMM
Old Oct 17, 2013 | 04:11 PM
  #44
j2the-e's Avatar
Never heard of water less coolant. Actually, water by itself cools much more efficiently than any coolant. The reason coolant is used is for corrosion protection, lubrication, and freeze protection.
Old Oct 17, 2013 | 04:34 PM
  #45
rworegon's Avatar
Evans Waterless Coolant is one.....I know nothing about using it.
A topic for a new thread......possibly.
Old Oct 18, 2013 | 10:43 AM
  #46
SqWADoosh's Avatar
Yeah I found out about this stuff watching an episode of "Wheeler Dealers" (love that show) recently.
Old Oct 18, 2013 | 02:37 PM
  #47
GrandPrix's Avatar
Not sure if Evans is the only but everything I have read makes sense. Especially the no expansion of the fluid to over pressurize and blow the head gasket.
Old Oct 18, 2013 | 08:11 PM
  #48
millball's Avatar
Any fluid/vapor pressure that the cooling system can exert on a headgasket is trivial. Those pressures cannot contribute in any meaningful way to headgasket failure.
Max cooling system pressures are well under 20psi.
Combustion pressures are hundreds of psi, alternating with vacuum
hundreds of times, if not thousands of times per minute.
That, coupled with radical temperature gradients, and the dissimilar coefficients of expansion of iron and light alloy, do the job on headgaskets.
Old Oct 19, 2013 | 08:50 AM
  #49
Umm... the radiator cap realeases pressure. That's what it's for. Waterless coolant is bad news.
Why would you want HIGHER internal temperatures? Higher temps reduces engine efficiency. Our fans are mechanical so the whole "save HP by not running fan" is a bunch of baloney.
Old Oct 19, 2013 | 12:27 PM
  #50
rustypigeon's Avatar
Not only that, but in cars with electrical fans, the fan only turns on when you are stuck in traffic. They never turn on when you are driving down the road with airflow over the radiator.
I saw that "not running fan" comment on the website and chuckled.
Old Oct 20, 2013 | 01:04 PM
  #51
SqWADoosh's Avatar
So just an update guys. Did my flush and my repair this weekend. Everything went great and I ended up going with Prestone Long Life Coolant. Thanks for all the recommendations and advice!
Old Oct 20, 2013 | 05:59 PM
  #52
Decided against the traditional green?
Old Oct 20, 2013 | 06:55 PM
  #53
islanti's Avatar
Why on earth!
Old Oct 20, 2013 | 06:59 PM
  #54
SqWADoosh's Avatar
Originally Posted by islanti
Why on earth!
Why on earth not?
Old Oct 20, 2013 | 07:58 PM
  #55
WD_40's Avatar
There is an excellent thread that details exactly what is going on with the various types of coolants. Well worth the read: https://www.yotatech.com/forums/f116...nt-faq-192781/
Old Oct 20, 2013 | 08:31 PM
  #56
nothingbetter's Avatar
Originally Posted by SCToy
May I point out you can just add distilled water to full. I run 25% coolant 75% water because it never gets cold enough to freeze here. No reason you can't just use distilled water until you can get more.
Your joking right? The ratio effects the freezing point as well as the boiling point. Running straight water will boil at 210f- 100c. If that happens you'll probally start blowing hoses from a huge pressure increase. The coolant also acts as a lubricant for the water pump. If you run straight water your water pump bearings won't like it. Ever think about corrosion? Corrosion inhibitors are in your coolant as well. Have fun cleaning your rusty block.
Old Oct 21, 2013 | 04:37 AM
  #57
redbayredneck's Avatar
Hate to argue, but that won't happen. The cooling system in the truck is pressurized, so water will not boil at 212F like it normally would.
A lot of drag cars run straight water in their cooling system without a problem.
Old Oct 21, 2013 | 06:24 PM
  #58
WD_40's Avatar
In a pinch you can run straight distilled water, but I wouldn't long term due to lack of pump lubrication and anti-corrosion properties that coolant provides.
Old Oct 21, 2013 | 08:14 PM
  #59
opps, I forgot about that. Thanks for the correction.
Old Oct 21, 2013 | 11:04 PM
  #60
osv's Avatar
osv
good thread.
since i'm sold on di/distilled water only in radiator systems, and I run the cheap peak antifreeze, I went to their website to see how much of a difference tap water makes:
"Can I mix ordinary tap water with antifreeze?
Yes, tap water is commonly used for mixing with antifreeze, however, deionized water or distilled water is preferred. Do not use water softened with salts to mix with antifreeze"
http://www.peakhd.com/product-lines/peak/faq/
