Replaced injectors now wont even crank
Old Jun 9, 2011 | 04:12 AM
no_3of4's Avatar
I have a 86 22re that had 2 bad injectors. It would still crank and run but not well. I replaced them last night and now it will not start. I double checked to make sure all wiring was hooked up and all lines good. Any thoughts would be greatly appreciated.
Old Jun 9, 2011 | 03:29 PM
scope103's Avatar
"Crank" usually means the starter will turn the engine over. I'll bet you mean it won't "fire," meaning the starter turns it, but you don't hear any combustion.
Pull the plugs. If they are dry, you're not getting any fuel. If they're wet, you're not getting any spark.
Old Jun 9, 2011 | 03:55 PM
coastal runner's Avatar
you can lose pressure in your fuel lines, which is what happened to me when i did mine. i had to crank mine over several times before the pressure came back.
Old Jun 14, 2011 | 05:20 AM
no_3of4's Avatar
Thanks, I found a broken ground wire for the injectors. I am now afraid that i have "trash" in the system. I have ran it only a few days and now one of the injectors has stopped working. Going to find out which one today and hopefully clean out what ever it is.
Old Jun 14, 2011 | 05:34 AM
TNRabbit's Avatar
You should change your fuel filter when you replace/clean injectors~
bigjstang
Jun 2, 2025 03:56 PM
steve miller
Oct 10, 2015 01:40 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
redneck17
Jul 17, 2015 07:44 PM
karbin
Jul 5, 2015 11:37 PM
