Removing LCA with a twist.
Old May 19, 2009 | 10:27 AM
Matt16's Avatar
We'd just done all the tough stuff and we were heading out off the trail. There was one rock sticking up that I thought was loose and thought I'd probably clear anyways. I was tired and misjudged it and hit the rock in 2nd gear low range. It bend the front LCA frame bracket.
To fix this, I'm going to need to remove the LCA, but the damage is preventing me from fixing the bracket.
Here's how it should be.
Here's the one that kissed a boulder a little too intimately.
The alignment still held tight and it is not affecting driveability in the least. I just don't want to chew up the LCA bushing and have no means to replace it.
Old May 19, 2009 | 10:31 AM
abecedarian's Avatar
might be able to get in there with a flat pry bar and pull it out. maybe using the short, hooked side and twist the bar.
Old May 19, 2009 | 10:36 AM
DeathCougar's Avatar
BFH perhaps?
Old May 19, 2009 | 01:50 PM
Matt16's Avatar
It would take a torch AND a BFH I think. The problem now is getting that LCA out.
1uzRunner
63
Nov 10, 2018 03:58 PM
Anthony Lee Mathis
Sep 15, 2015 07:22 AM
LotOMiles
Sep 14, 2015 11:45 PM
Rickstwowheels
Sep 9, 2015 06:12 PM
gp66
Sep 7, 2015 08:29 AM
