Removing the Crankshaft Pulley Bolt Question
Old Apr 8, 2011 | 10:10 AM
sb5walker's Avatar
Originally Posted by NJRunner86
yeah, that was a real "noob" thing to post, huh?
Yeah but. We were all noobs once. And I guess we're all noobs at a lot of other subjects...
But seriously, I think it's pretty common to have a harmonic balancer and pulley on the front end of a crank, and for the pulley to have timing marks.
Old Apr 8, 2011 | 12:56 PM
NJRunner86's Avatar
I've always been a domestic small block guy. That is all of my experience. On fords and chevys, the mark in the harmonic balancer is what you set your timing with. Because of that, it doesn't matter how you bolt your crank pulley to your balancer because it's only purpose is to move the belt(s).
As I now know, the 22re has a pulley that fits back over the balancer so it is used as the timing mark. Pretty smart thinking on the part of the Toyota engineers if you ask me.
Old Apr 9, 2011 | 01:19 AM
Bassmastry101's Avatar
Isn't the 0 degree mark TDC? Someone please correct me if I'm wrong.
This might help you out a bit.. http://www.ncttora.com/fsm/1993/1993.zip
That's the service manual for a 93 pickup..should be pretty much the same.
Old Apr 9, 2011 | 07:29 AM
stupid_mud_gremlins's Avatar
Umm, I've been out for a long time, but it seems like everyone has kinda forgotten the rope-in-cylinder trick. I've used this a couple times, and although it may not be the *best* thing for your engine, it does work. After you remove the coil wire:
1) Position engine at TDC
2) Turn the crank using the pulley 1/4 turn clockwise to bring the piston down a little bit.
3) Pull the #1 Spark plug and insert nylon rope into the spark plug hole till the space fills up
4) Pull the breaker bar back to put pressure on the rope and break the stinkin' thing loose.
What can I say...is ny redneck showing?
Old Apr 9, 2011 | 09:16 PM
  #25
So basically, your saying the rope will stop the piston from coming back up and break loose the bolt?
Sep 4, 2015 09:27 AM
DrZero
18
Jul 24, 2015 11:31 PM
dinks07
Jul 15, 2015 05:34 PM
KBar
Jul 13, 2015 06:01 PM
Snort
Jul 9, 2015 03:58 PM
