Rear Window Relay
Rear Window Relay
hey guys i was just wondering if anyone would be interested in new control boards for our rear windows. i was thinking about redesigning it a little bit and reproducing them. i just want to gauge interest before i go ahead on it. mine recently went bad and that is what gave me the idea. i could do a slight redesign and make them mount in the same spot using the same holes and also be waterproof. let me know what you guys think. this could be done for under $100. which is pretty good considering the relay setup is $250 from toyota.
I am too. My rear window wiring has been hacked up and rewired directly off the battery, eliminating the ability to raise/lower it with the key. The previous owner did this for some reason. I think i need a little more than a new control board, however.
As bad as i tried not to post........ gaaa can't help it. The fact that the wiring has been totally messed up and no longer OEM you may never get it working properly like it did before.... Rear window relays rarely go bad on these trucks and it prob was not even bad.... but you could wire it from the battery..... You know the rear window relay is behind the driver seat in the quarter panel bellow the rear passnager window right.....? behind that panel.... personally i think all the work you doing is way to rediculous and a new relay(if it was bad) would have been a smarter choice.....
mine is bad also.. seams to be a common problem.
here is a link that might help. http://www.4crawler.com/4x4/CheapTri...arWindow.shtml
www.12voltguy.com sells this kit for $76.99 shipped
http://www.pirate4x4.com/forum/showthread.php?t=564548
Jun 1, 2021 01:51 PM
icentropy
Jul 14, 2015 10:23 AM
Johntom240
7
Jul 13, 2015 12:18 AM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
Jul 6, 2015 04:07 AM
