Rear window problems
Old Feb 12, 2009 | 03:21 PM
woodendude's Avatar
Was driving home from work today and a short distance from home my "door open" dash light started to flicker off and on. It wasn't flickering to brightly but it was going on and off. So when I get home I'm thinking maybe the rear door is not closed properly so I roll down the window with the key unlock it , open it up, slam it closed and go to roll up the window...... nohing happens. I've opened and closed the door a few times, nothing happens. I opened up the inside skin of the door, peeled the plastic back and did a visual check, all wiring looks good, all connections seem okay. With the door open, but the locks latched to similate the door being closed it beeps when I try the window, this has also happen with the door closed. I've run out of daylight and it's getting cold out so I taped plastic over it and will get back to it in a day or two. What should I be looking for? My thinking is:
Check for current making to the window motor,
How do I check the relay switch?
Could it be the door closed sensor, and how do I check this?
Would appreciate any help you can give me, it's winter out there and I need my window closed. I do have another tailgate with a working motor and all guts but I'd rather fix this one if I can.
Derek
Old Feb 13, 2009 | 02:37 AM
woodendude's Avatar
I hoping to get to this problem this week end and with the reading I've done here I think I have a solution figured out.
If I directly wire the motor with 12v and it works, then chances are it the relay, right?
If it the relay, I swap out the switch box with an extra that I have.
If niether works, it's the closed door sensor, right? I so, where is it located and whats a fix for it.
Need some help guys it's like minus 20 c here and I wouldn't mind a closed rear window.
Truck info is in my Sig.
Old Feb 13, 2009 | 05:51 PM
LITLRED's Avatar
I'm new at this but I'll pass on how I fixed mine. The rear window was dead when i bought my rig. When I was checking for voltage with the switch forced on the window started down, which I wasn't expecting. The various safteys and switches are on the ground side and by shorting the circut to ground I completed the circut and the window worked. This way I traced the open ground to the door latch so I pulled it and sure enough there was no continuity. I temporarily fixed it by running a wire to ground before the latch.
Old Feb 13, 2009 | 06:25 PM
waskillywabbit's Avatar
Learn to use and search this forum
http://www.4crawler.com/4x4/CheapTri...arWindow.shtml
Old Feb 13, 2009 | 06:47 PM
woodendude's Avatar
I guess you missed the part where I said "with the reading I've done here I think I have a solution figured out. "
Old Feb 13, 2009 | 06:50 PM
Touche'. My apologies.
But I saw no mention of 4crawler's website. I've fixed numerous rear window problems reading his website.
Old Feb 13, 2009 | 07:14 PM
Tubbyfatty's Avatar
You can roll your window down with the key? I can only roll mine up. When its up and i turn the key to either side nothing happens.
Old Feb 14, 2009 | 03:38 AM
woodendude's Avatar
Yeah mine went both up and down with the key, but presently I'm not putting it down until the warmer weather gets here. I was able to jump the motor directly and get the window up but I won't be properly fixing it unti it's warmer out as I don't have a garage. It sucks not having a garage I have a nice ARB front bumper I bought used, sanded, painted and am now waiting for warm weather to install, it's driving my nuts having it sitting on my basement floor.
Jun 1, 2021 01:51 PM
icentropy
Jul 11, 2015 07:21 AM
Jnkml
Jul 6, 2015 01:20 PM
coryc85
Jul 6, 2015 04:07 AM
