rear tires wearing weird axel help?
my rear tires are wearing real bad on the insides and look brand new on the outsides, anyone got any idea whats wrong with the truck?
thanks
justin
thanks
justin
If the rear axle, you might try measuring the front and back tire width (measure from tire to tire across the front and back of the tires) and see if there is any toe in (or out), possibly due to a bent axle housing. You should measure no difference between the same part of the tire front to back. Or you could run a string along both sides of the truck, having it just touch the sides of the rear tire and see where the strings line up (should be parallel). Also, might be a camber issue (again due to a bent housing). Use an angle finder or square to check that the rear wheels sit perfectly vertical.
Jun 1, 2021 01:51 PM
djpg2000
Nov 11, 2020 04:56 AM
icentropy
Jul 14, 2015 10:23 AM
jon.r
Jul 11, 2015 03:34 PM
