Rear Tires not rotating freely
'90 pickup 4wd,SR5 3.0 I just bought this truck and while inspecting the rear drums I noticed that If I spun one of the rear tires(which was hard) it didn't make any foul noises but it would not spin one inch without help. My question is what would be considered normal, and what order would a guy start looking into parts to find the cause
not always, sometimes the brakes just are a little too tight and dont make much noise, maybe a little rub here and there, pull tire and drum off and try turning the axle then, if its still really hard to move then i would say bearings, if its a easyer then its the brakes are too tight,
that makes sense. my next obstacle will be getting the tire off on rear drivers side. I beat it like it owed me money and couldn't get the tire and rim off the hub. I'm also thinking that maybe the cold had something to do with it, so tomorrow I will make sure everything is warmed up before I get after it. Thanks for the responses I'll let you know what I find tomorrow
u mean u couldnt get the lug nuts off? sounds like someone put them on too tight and might of stripped them, i would get a breaker bar and try then if not u are going to have to just get a bar on them and keep at it tell they brake or brake free...
How hard is it to turn? You will be turning another wheel/driveshaft
Soak the wheel around the center hub with PB Blaster, let sit for a couple of hours, then sit in front on the tire & alternate hitting each side with the heel of your foot HARD. Should break it loose. These wheels are HUB centric, which means they center on the hub instead of the lug bolts. As such, it's a tight fit.
You'll also need a couple of bolts to back the drum off if it's that tight. Forget which size, they are metric. You screw them into the holes on opposite sides & tighten alternately to get the drum off.
Flying91
45
Apr 11, 2024 04:39 PM
Jun 1, 2021 01:51 PM
djpg2000
Nov 11, 2020 04:56 AM
