rear axle seal?
Old Mar 19, 2007 | 10:36 PM
Sonofmayhem's Avatar
rear axle seal?
ive heard that they were a beyotch to replace, now i know my outter seal is bad, it leaves diff fluid on my driveway everynight so HOW do i do this? i havent done it yet. i figure i can get the inner and outer seal and a bearing and be straight, but i just need to know how to do it.
Old Mar 20, 2007 | 12:20 AM
91 4Runner's Avatar
I did this just last weekend. It's easy... Pull tire. Undo rear brake line from the wheel cylinder (and plug it) Pull off drum and undo parking brake cable, and undo the two bolts that hold it to the backing plate and pull through. Remove 4 nuts on the rear of hub (close to the axle) pull out axle shaft as a whole. Pop old seal out with a screwdriver and carefully tap in the new one ( make sure it goes in straight and all the way) I used a short 2x4 to tap evenly. then reverse the steps to put it all together...
Old Mar 20, 2007 | 01:34 AM
leebee's Avatar
if you are planning on doing the brgs as well, youll need access to a press.
lee
Old Mar 20, 2007 | 05:25 AM
waskillywabbit's Avatar
Not a bad fix at all but as mentioned you will need access to a press to do bearings.
We have the rear kits.
Old Mar 20, 2007 | 01:15 PM
yeah, but i cant afford dem' for awhile
I think if i can get away without doing the bearings and just doing the inner seal id be happy.
Old Mar 20, 2007 | 01:27 PM
Elvota's Avatar
I'd jump on this repair soon.
It's my understanding that the bearings don't care much for being contaminated with gear oil... not to mention the brake hardware.
Be a shame to "have" to replace those bearings if funds are tight.
Old Mar 20, 2007 | 05:05 PM
i know its like 350 a side at a shop but i am purty tight on cash im trying to save to have my tcase setup, and flatbedding my truck
Old Mar 20, 2007 | 05:49 PM
carose725's Avatar
im surprised your bearings arent eaten up, i had to do mine about two weeks ago, a seal went bad and destroyed the bearing in no time. the tear down is very and reinstall is cake, but you will need to find someone to press the bearings for you. i would definately replace the inner, outer seals, bearings. most likely your rear brakes will need to be replaced also. it ended up costing me about $200 for all seals, brakes shoes, bearings, and new drums.
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
Iceman4193
Jul 15, 2015 04:48 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
toyoda8488
Jul 5, 2015 10:18 PM
