Rear axle leaf spring lift done the wrong way
Old Apr 2, 2010 | 08:02 PM
yotaman85's Avatar
maybe the ubolts are are from a flip kit. try putting the ubolts around the axle and the plate on top of the leaf springs.. and your bolt idea is ok. just make sure to get a proper replacement soon.. good luck man.
Old Apr 2, 2010 | 08:08 PM
bb7110's Avatar
Thanks, Yotaman. I'm waiting on the right bolts. This trucks had enough of half arsed maintenance. I'm doing it right the first time. =) I can't have an axle fly off on the way out to the desert.
Old Apr 2, 2010 | 08:37 PM
peow130's Avatar
bb7110.
While you're in there, why not invest in a U-bolt flip kit?
If you do some wheeling it's a pretty trick mod that'll get you the new u-bolts you need and the new top plate. if you have access to a welder you're golden.
Old Apr 3, 2010 | 11:26 AM
akaphilly's Avatar
yes please get the u-bolt flip kit. and also looks like a 6 degree shim. which are sold at summit. i actually run a set and have no problems. just make sure you tighten the u bolts every few weeks
Old Apr 3, 2010 | 11:28 AM
  #25
Duckie's Avatar
Autozone sells a pack of 4 ubolts with hardware for 14.99. They are flattop, and really long (like 16" lol), but I used them and cut them down when I did my Zuk coil mod. They say they are made for lift blocks, but they are threaded up high enough to use without them.
Old Apr 3, 2010 | 01:01 PM
  #26
Philbert's Avatar
Wow - that's crazy!
Defintely replace those U bolts with the square ones ASAP - and get a center leaf alignment bolt set in there (dealer?). If you do the flip kit ($50 or so) you'll need to weld the shock mount tabs I believe.
Torque specs for the U bolts are 90 ft/lbs btw -I just did this on my ZUK mod.
Still concerned about the leaf in between the pack and the overload leaf - what the hell is that????
Old Apr 3, 2010 | 04:44 PM
  #27
Jay351's Avatar
those u-bolts are awesome!
Gotta love booty fabbin'
Old Apr 3, 2010 | 05:19 PM
  #28
ILLINOISYOTADAWG's Avatar
that is some fine redneck wrenching right there wtf was the owner smoking to be that stupid
Old Apr 3, 2010 | 06:01 PM
  #29
rattlewagon's Avatar
Yeah, that dosent look safe at all! You didnt spot that when you bought it? i say skip the block and get longer shackles to compensate.
Old Aug 25, 2010 | 09:36 AM
  #30
Ahbustae86's Avatar
Just get good blocks and new U bolts. Looks like a make shift shim to reduce the drive shaft angle. Either way looks crazy.
Old Aug 25, 2010 | 09:45 AM
  #31
cubuff4runner's Avatar
I am guessing that since he posted this in April and there have been no more posts the issue has been resolved for awhile.
Old Aug 25, 2010 | 11:59 AM
  #32
kiyobrown's Avatar
Dude, Its been so long since I have seen this thread I had to reread it to figure out why I had a subscription......
Jun 1, 2021 01:51 PM
jerusry
Oct 19, 2015 05:28 PM
Nickdigg
Jul 7, 2015 06:04 AM
toyoda8488
Jul 5, 2015 10:18 PM
Vargntucson
Jul 4, 2015 12:15 PM
