Rear axle leaf spring lift done the wrong way
maybe the ubolts are are from a flip kit. try putting the ubolts around the axle and the plate on top of the leaf springs.. and your bolt idea is ok. just make sure to get a proper replacement soon.. good luck man.
bb7110.
While you're in there, why not invest in a U-bolt flip kit?
If you do some wheeling it's a pretty trick mod that'll get you the new u-bolts you need and the new top plate. if you have access to a welder you're golden.
#25
Autozone sells a pack of 4 ubolts with hardware for 14.99. They are flattop, and really long (like 16" lol), but I used them and cut them down when I did my Zuk coil mod. They say they are made for lift blocks, but they are threaded up high enough to use without them.
#26
Wow - that's crazy!
Defintely replace those U bolts with the square ones ASAP - and get a center leaf alignment bolt set in there (dealer?). If you do the flip kit ($50 or so) you'll need to weld the shock mount tabs I believe.
Torque specs for the U bolts are 90 ft/lbs btw -I just did this on my ZUK mod.
Still concerned about the leaf in between the pack and the overload leaf - what the hell is that????
#31
Jun 1, 2021 01:51 PM
jerusry
Oct 19, 2015 05:28 PM
toyoda8488
Jul 5, 2015 10:18 PM
Vargntucson
Jul 4, 2015 12:15 PM
