Rear Axel Sheared apart!!
Old 08-22-2007, 08:04 PM
drew303's Avatar
if you wanted to salvage the backing plate you could cut the flange on the end of the axle *has the wheel studs* down so that the backing plate fits over it.
the backing plate and bearing case are two separate parts.. New bearing cases are $53 @ the dealer. not sure on backing plates.
Old 08-22-2007, 08:06 PM
shoes138's Avatar
damn that suxs hope you find the cause if that! thats hella werid how it just sheard off@!
Old 08-22-2007, 09:11 PM
MudHippy's Avatar
Originally Posted by drew303
how are you cutting into the bearing if its stuck in the bearing case?
I'm don't mean cut the bearing itself, though if it's getting replaced you don't need to be carefull not to. Just cut the bearing retainer ring off, if you don't have the SST to get it off.
The bearings aren't no where near as snug a fit as that retainer ring, I was able to to knock them off relatively easily by the method I described once I got the retainers off.
Doing such to salvage that backing plate and bearing case should work too. I mean cut the retainer, then hold the backing plate steady and beat(broken end)the axle stub out of the bearing.
Old 08-22-2007, 09:30 PM
Elvota's Avatar
This link has a couple ways to get the bearings off. I haven't tried either, but maybe they will help you.
http://www.4x4wire.com/toyota/mainte...wheel_bearing/
One cool thing about the disc swap I did, is that you no longer need the backing plates at all. So the extra set of axles and bearings I got from the salvage yard... well, I just cut the backing plates off and can slip in an entire new axle/ bearing assembly very quickly. Just undo the for axle to housing bolts and I am good to go. Great for a trail repair should I ever need one.
Mind you, I'd still have to figure out how to get the broken end out of the housing... but all in all a simpler way to go.
Old 08-22-2007, 09:41 PM
  #25
MudHippy's Avatar
Good link, explains everything I have tried to advise, possibly better than I did and with pics!
Old 08-23-2007, 03:17 PM
  #26
MUDN4R's Avatar
ok thanks guys! im going with 2 new axles (chromoly), new inner and outer seals, bearings, and a co-worker of mine just got a 5.29 equipped third (all new everything from ZUK) that imma put a locker in since its already out so i should be good to go! mit take the broken axle to a machine shop to have them press it out since we dont do cars at work..
Old 08-23-2007, 03:42 PM
  #27
curtiswyant's Avatar
I'd just get a complete junkyard rear axle assembly and swap it in. Keep what's left of yours for spare parts. That way you wouldn't have to worry about new bearings and what not, and it would only be $100-150 total, and you'd have a nearly complete set of spares
Old 08-23-2007, 05:40 PM
  #28
waskillywabbit's Avatar
You have a PM.
oldirtydirt
02-23-2020 09:30 AM
kirkrunner
07-27-2015 07:59 PM
SMOD
07-27-2015 01:45 PM
Iceman4193
07-15-2015 04:48 PM
icentropy
07-14-2015 10:23 AM
Quick Reply: Rear Axel Sheared apart!!
