Really BAD Gas Mileage
Old Mar 8, 2007 | 06:56 PM
  #61
longhungsilver's Avatar
Originally Posted by Chapman88SR5
Update...
The connection to fuel injector #1 was un-plugged! Plugged it back in and no more sputter.
Put seafoam in tonight and will start it up tomorrow.
Perhaps your fuel injector was unplugged cuz when you take off the throttle body to get at the coolant hoses u need to unplug the #1 fuel injector (i had to on my truck when taking the tb off to clean it)
and wuts this seafoam??
Old Mar 8, 2007 | 07:15 PM
  #62
rhah's Avatar
Chapman88SR5 you sloved the problem before I could tell you my experence. I had the exact same issue as you and the exact same fix.
Old Mar 13, 2007 | 07:57 PM
  #63
*Bump* any update ?? was that the end of your problems? Hows the yota running now?
Old Mar 14, 2007 | 05:46 PM
  #64
86 TurboSR5's Avatar
22mpg city 33 highway for my stock x cab turbo
Old Apr 23, 2011 | 09:58 AM
  #65
Hackuba's Avatar
Old Apr 23, 2011 | 05:48 PM
  #66
Badger62811's Avatar
Just throwing this out there... My 94 22RE 4x4 has a 17 gallon tank. The gas gauge goes WAY lower than the E. With the needle completely on the left side of the E, I can usually still put in 15 gal. Haven't run outta gas yet.
And it sounds like the #1 injector was unplugged...
Old Apr 27, 2011 | 09:05 PM
  #67
viker350's Avatar
ok i have this problem to i get bad milege on my 86 pickup it has a 22re
Old Apr 27, 2011 | 09:36 PM
  #68
4x4climber's Avatar
Originally Posted by 4x4countrygirl
Just got new rims and tires put on last week... so they were just mounted and balanced and should be properly inflated.
Never assume anything. most places that install tires leave them at 40+psi.... for EVERY car.
And my guess would be that you have a bad fuel injector. or multiples. have you have them checked or tested them to be in good working order?
Old Apr 29, 2011 | 11:15 AM
  #69
VegasNaturist's Avatar
One other thing to check in these absurdly low mileage issues is the fuel pressure regulator. If the diaphragm inside has deteriorated, you may be sucking raw fuel through the vacuum line... Just a thought.
John
Charecter1
Nov 6, 2023 10:08 AM
Eggslinger
Jun 8, 2019 03:32 PM
shisha1999
Sep 21, 2015 08:22 PM
pyramid
Jul 30, 2015 10:05 AM
daddio
Jul 18, 2015 10:20 AM
