radio help
Old Sep 28, 2008 | 12:19 PM
87pickup's Avatar
radio help
i have an aftermarket jvc head unit. when the truck is in acc or even when the key is out it works, but when i turn the truck on it just flashes and doesnt turn on. help please!
Old Sep 28, 2008 | 12:26 PM
bigarms23's Avatar
re check your wiring it sounds like you have inverted one wire
Old Sep 28, 2008 | 12:53 PM
87pickup's Avatar
well i got it to work while the truck is running but it still works while there is no key in the truck.
Old Sep 28, 2008 | 02:05 PM
jason191918's Avatar
Your accessory power wire must be hooked up to a full time power wire, and not an accessory power wire.
Old Sep 28, 2008 | 03:18 PM
toylocost's Avatar
From: Yotatech, because Pirate is too expensive. NorCal.
Just as his signature says "Jason is right."
Old Sep 28, 2008 | 03:21 PM
dbcx's Avatar
Yup, it needs constant power for the memory.
Find a switched hot wire for power.
Find a constant hot for the memory.
Old Sep 28, 2008 | 03:41 PM
scuba's Avatar
I fully concur
Old Sep 28, 2008 | 05:50 PM
87pickup's Avatar
thanks a lot guys i got it.
kawazx636
Oct 6, 2021 03:03 PM
mct75
Aug 22, 2016 01:24 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
tazman1972
11
Sep 28, 2015 10:32 PM
ctheiss
Sep 14, 2015 12:18 PM
