Radio gray ignition always on
Old Jun 29, 2022 | 05:42 AM
Vagaso's Avatar
Pretty new to these trucks and had to gut a terrible radio from the dash and out a stock one back in. Wired it all up with stock connectors and the gray has constant power, not switched. Is there a common issue I don't know about? I heard it's direct from the ignition switch?
Old Jun 29, 2022 | 07:27 AM
scope103's Avatar
Gray should be from the Radio fuse, which is on the ACC (switched) line. (Along with CIG.) The ACC line should be L-R.
Other than it being common that a vehicle that old has "a terrible radio," I don't know of any particular issue. Use your multimeter to confirm Gray goes to Radio, and Radio is switched.
Old Jun 29, 2022 | 07:41 AM
Vagaso's Avatar
By terrible radio i meant old aftermarket radio wired badly. All the diagrams show gray as 12v ignition. The radio has a constant 12v for the memory and the 12v ignition (gray) is used to actually power on so it is switched.
As for checking the fuse I'll have to check when I get home. I feel like it's gotta have constant power too or it's shorting on its way to the radio. I can turn the radio on whenever I want regardless of key position.
There is a slow phantom power draw and I'm guessing it's this as well.
Old Jun 29, 2022 | 08:41 AM
scope103's Avatar
I knew what you meant.
If it helps, "constant" battery should be on L-Y from the Dome fuse.
I'd be surprised if your radio is drawing enough to be called a phantom power draw, but testing that is with an ammeter.
uh1medic
10
Dec 21, 2016 07:54 PM
warracer
Nov 10, 2015 05:05 PM
kentucky_dan
Apr 11, 2007 11:40 AM
uberhahn
Aug 2, 2006 07:47 PM
travco
May 9, 2004 02:39 PM
