Radio antenna
Old Nov 11, 2017 | 07:37 AM
cranky's Avatar
Radio antenna
1994 Toyota hi-lux pickup. How do you get to radio antenna to remove the wire. It's a manual antenna. Already removed from fender.
Old Nov 11, 2017 | 01:23 PM
wyoming9's Avatar
Red face
Not sure just what your asking
The antenna plugs into the back of the radio remove the radio to unplug the antenna pull the antenna lead out through the fender
If your replacing the antenna
Feed the antenna wire in from the outside through the grommet so it does not abrade on the metal
If the grommet is dry rotted I use Silicone
I hope that helps
Scjarena
Jan 6, 2023 06:11 AM
toyospearo
Jan 11, 2018 05:21 PM
ddankanyin
16
Nov 4, 2017 01:11 AM
Katoner
Sep 12, 2017 01:59 PM
